Author Topic: Can't StarAlign NB subframes  (Read 628 times)
Offline MineralMike
« on: 2019 January 16 11:44:38 »
I have two sets of debayered OSC subs of M42 -- one in full color and the second with an Ha filter. Shen I try to register these subs, StarAlignment fails with an "Unable to find an initial set of putative star pair matches" error. I have attached the Process Console output for a run containing just one full-color sub, and one Ha sub.
The problem occurs with the full-color sub as reference and with the Ha sub as reference. Per Keller's book, I have lowered the Log setting to include dimmer stars.
The problem occurs when StarAlignment attempts to register the Ha subs -- the full-color subs end up in the output directory.
Inspection of the Ha subs reveals at least 15 stars, while the full-color subs have many stars.
What must I do to get the Ha subs aligned?
Thanks for all advice.
--- Mike
Re: Can't StarAlign NB subframes
« Reply #1 on: 2019 January 16 13:29:29 »
you will need to post links to a few example images. this kind of thing can only be answered thru experimentation...
Offline MineralMike
« Reply #2 on: 2019 January 16 22:20:44 »
I zipped one full-color sub and one Ha sub into this file: http://astronomy.mdodd.com/M42_(Mike_Dodd).zip (232 MB). StarAlign fails when processing just these two files, regardless whether the full-color sub or the Ha sub is the reference.
Both files are calibrated and debayered.
Thanks again for any pointers on how to get StarAlign to work with my subs.
--- Mike
« Reply #3 on: 2019 January 16 23:19:54 »
First I reset StarAlign to make sure any old settings were gone. Then using the 'Clear' as the reference image I only changed the Noise Reduction setting from 0 to 1. The Ha image aligned without issue.
Offline MineralMike
« Reply #4 on: 2019 January 17 10:50:27 »
That did the trick. Thanks!
I added a new StarAlign instance to my PI workspace, then save the project as a "narrowband" variation.
Thanks again.
--- Mike
