Author Topic: Anyone See Faint Bubble Near LDN 1468?  (Read 582 times)
Offline kerrywaz1
    • Spirit Bear Observatory
« on: 2019 January 13 15:03:32 »
Hi All,
I was processing some luminance data from 09/15/2018 of the region around IC348 and noticed a faint bubble in the calibrated and integrated luminance image near LDN1468 (see attached). I can't tell if this is a real bubble or an errant dust doughnut that crept in somehow (no doughnuts there in the master flat) and didn't get processed out. The weather here has sucked for the past several weeks and I can't re-image and the internet doesn't seem to have a high resolution image to check this. Has anyone else seen a bubble in this spot?
Kerry
Deep Sky Instruments RC14C
FLI PL16803 w/MOAG + StarlightXpress Ultrastar
Pyxis 3"
Astro Physics AP1200
Tak FSQ-106EDXII
Apogee Alta F16M
Hap Griffin modified Canon EOS 5D Mark II
PixInsight, MaxIm DL, PhotoShop CS5
Offline dld
Re: Anyone See Faint Bubble Near LDN 1468?
« Reply #1 on: 2019 January 14 01:00:00 »
Hello Kerry,
The following astrobin search query,
https://www.astrobin.com/search/?q=IC%20348&field_radius_max=8.0&field_radius_min=0.0&d=i&t=all&sort=-likes
will bring you some deep images from respected astrophotographers. At a quick glance, I couldn't see the bubble there. But I might be wrong.
Offline kerrywaz1
« Reply #2 on: 2019 January 14 21:06:57 »
There is a really bright star just out of frame and I think it may have caused an optical effect, i.e.a circular lens flare.
--- Kerry
Pyxis 3"
Tak FSQ-106EDXII
Apogee Alta F16M
