Author Topic: PCL Win32 System Exception: At address ... LibRAW Error  (Read 1073 times)
Offline jimwaters
« on: 2019 January 06 18:56:58 »
I am running 1.8.6.1448.  I just got a LibRAW error doing BatchPreprocessing.  I can reproduce the problem.  I am running Win7 x64 that's up to date on a Lenovo E440 Laptop with 16Gbytes of memory.
EDIT - The camera was a Canon T3i and NOT using a CWB.
Auto crop ................. enabled
White balancing ........... disabled
Auto rotate ............... disabled
Output image .............. w=5202 h=3465 n=1 Gray
Reading RAW data: done
Scaling colors: done
Pre-interpolating: done
Converting to RGB:
Computing image statistics: done
Weight          :     1.00000
[004] E:/M101/Bias/_MG_0104.CR2
E:/M101/Bias/_MG_0099.CR2
Reading metadata: done
Camera ........... Canon EOS 600D
Timestamp ........ 2012-04-27T22:16:29Z
Exposure ......... 1/4000s
ISO speed ........ 800
Focal length ..... 50 mm
CFA pattern ...... Bayer RGGB
Raw dimensions ... w=5344 h=3516
Image geometry ... x=142 y=51 w=5202 h=3465
Raw decoding parameters:
Output mode ............... cfa
Converting to RGB:
Weight          :     1.00000
[005] E:/M101/Bias/_MG_0105.CR2
E:/M101/Bias/M101_BIAS_Tv14000s_800iso_00104_20171001-16h46m11s999ms.CR2
Timestamp ........ 2017-10-02T00:16:41Z
Converting to RGB:
Weight          :     1.00000
[007] E:/M101/Bias/_MG_0106.CR2
E:/M101/Bias/M101_BIAS_Tv14000s_800iso_00104_20171001-16h47m11s306ms.CR2
Timestamp ........ 2017-10-02T00:17:40Z
Converting to RGB:
Weight          :     1.00000
[000] E:/M101/Bias/_MG_0107.CR2
* Waiting for running tasks to terminate...
E:/M101/Bias/_MG_0100.CR2
Timestamp ........ 2012-04-27T22:16:30Z
Converting to RGB:
Weight          :     1.00000
E:/M101/Bias/_MG_0101.CR2
Timestamp ........ 2012-04-27T22:16:31Z
Converting to RGB:
Weight          :     1.00000
Timestamp ........ 2012-04-27T22:16:35Z
Converting to RGB:
Weight          :     1.00000
Timestamp ........ 2012-04-27T22:16:36Z
Converting to RGB:
Weight          :     1.00000
Timestamp ........ 2012-04-27T22:16:38Z
Converting to RGB:
Weight          :     1.00000
Timestamp ........ 2012-04-27T22:16:39Z
Converting to RGB:
Weight          :     1.00000
E:/M101/Bias/_MG_0102.CR2
Timestamp ........ 2012-04-27T22:16:33Z
Converting to RGB:
Weight          :     1.00000
E:/M101/Bias/_MG_0103.CR2
Timestamp ........ 2012-04-27T22:16:34Z
Converting to RGB:
Weight          :     1.00000
Integration of 40 images:
Pixel combination .................. average
Output normalization ............... none
Weighting mode ..................... don't care
Scale estimator .................... MAD
Pixel rejection .................... sigma clipping
Rejection normalization ............ none
Rejection clippings ................ low=yes high=yes
Rejection parameters ............... sigma_low=4.000 sigma_high=3.000
* Using 320 concurrent pixel stack(s) = 1022.37 MiB
Integrating pixel rows:     0 ->  3464: done
Pixel rejection counts:
E:/M101/Bias/M101_BIAS_Tv14000s_800iso_00089_20171001-16h45m31s937ms.CR2
    1 :     26987   0.150% (     1480 +     25507 =   0.008% +   0.142%)
E:/M101/Bias/M101_BIAS_Tv14000s_800iso_00092_20171001-16h44m04s025ms.CR2
    2 :     23385   0.130% (     1569 +     21816 =   0.009% +   0.121%)
E:/M101/Bias/M101_BIAS_Tv14000s_800iso_00092_20171001-16h45m51s322ms.CR2
    3 :     27983   0.155% (     1538 +     26445 =   0.009% +   0.147%)
E:/M101/Bias/M101_BIAS_Tv14000s_800iso_00092_20171001-16h46m01s617ms.CR2
    4 :     24723   0.137% (     1601 +     23122 =   0.009% +   0.128%)
E:/M101/Bias/M101_BIAS_Tv14000s_800iso_00092_20171001-16h46m41s038ms.CR2
    5 :     24427   0.136% (     1606 +     22821 =   0.009% +   0.127%)
E:/M101/Bias/M101_BIAS_Tv14000s_800iso_00092_20171001-16h47m21s314ms.CR2
    6 :     23206   0.129% (     1641 +     21565 =   0.009% +   0.120%)
E:/M101/Bias/M101_BIAS_Tv14000s_800iso_00094_20171001-16h47m01s261ms.CR2
    7 :     28087   0.156% (     1569 +     26518 =   0.009% +   0.147%)
E:/M101/Bias/M101_BIAS_Tv14000s_800iso_00094_20171001-16h47m31s276ms.CR2
    8 :     28139   0.156% (     1578 +     26561 =   0.009% +   0.147%)
E:/M101/Bias/M101_BIAS_Tv14000s_800iso_00097_20171001-16h43m25s776ms.CR2
    9 :     27750   0.154% (     1499 +     26251 =   0.008% +   0.146%)
E:/M101/Bias/M101_BIAS_Tv14000s_800iso_00097_20171001-16h43m35s792ms.CR2
   10 :     27600   0.153% (     1569 +     26031 =   0.009% +   0.144%)
E:/M101/Bias/M101_BIAS_Tv14000s_800iso_00097_20171001-16h44m44s506ms.CR2
   11 :     27448   0.152% (     1495 +     25953 =   0.008% +   0.144%)
E:/M101/Bias/M101_BIAS_Tv14000s_800iso_00097_20171001-16h44m53s578ms.CR2
   12 :     27862   0.155% (     1524 +     26338 =   0.008% +   0.146%)
E:/M101/Bias/M101_BIAS_Tv14000s_800iso_00097_20171001-16h46m51s175ms.CR2
   13 :     27787   0.154% (     1562 +     26225 =   0.009% +   0.145%)
E:/M101/Bias/M101_BIAS_Tv14000s_800iso_00097_20171001-16h47m51s505ms.CR2
   14 :     27895   0.155% (     1512 +     26383 =   0.008% +   0.146%)
E:/M101/Bias/M101_BIAS_Tv14000s_800iso_00099_20171001-16h44m24s240ms.CR2
   15 :     28860   0.160% (     1538 +     27322 =   0.009% +   0.152%)
E:/M101/Bias/M101_BIAS_Tv14000s_800iso_00099_20171001-16h45m41s114ms.CR2
   16 :     24237   0.134% (     1574 +     22663 =   0.009% +   0.126%)
E:/M101/Bias/M101_BIAS_Tv14000s_800iso_00099_20171001-16h46m31s975ms.CR2
   17 :     28729   0.159% (     1501 +     27228 =   0.008% +   0.151%)
E:/M101/Bias/M101_BIAS_Tv14000s_800iso_00099_20171001-16h48m08s165ms.CR2
   18 :     26051   0.145% (     1540 +     24511 =   0.009% +   0.136%)
E:/M101/Bias/M101_BIAS_Tv14000s_800iso_00101_20171001-16h43m44s929ms.CR2
   19 :     26819   0.149% (     1511 +     25308 =   0.008% +   0.140%)
E:/M101/Bias/M101_BIAS_Tv14000s_800iso_00101_20171001-16h44m34s400ms.CR2
   20 :     25939   0.144% (     1554 +     24385 =   0.009% +   0.135%)
E:/M101/Bias/M101_BIAS_Tv14000s_800iso_00101_20171001-16h45m03s713ms.CR2
   21 :     25957   0.144% (     1567 +     24390 =   0.009% +   0.135%)
E:/M101/Bias/M101_BIAS_Tv14000s_800iso_00101_20171001-16h45m12s683ms.CR2
   22 :     26166   0.145% (     1535 +     24631 =   0.009% +   0.137%)
E:/M101/Bias/M101_BIAS_Tv14000s_800iso_00101_20171001-16h45m21s786ms.CR2
   23 :     27782   0.154% (     1472 +     26310 =   0.008% +   0.146%)
E:/M101/Bias/M101_BIAS_Tv14000s_800iso_00101_20171001-16h47m59s837ms.CR2
   24 :     28489   0.158% (     1461 +     27028 =   0.008% +   0.150%)
E:/M101/Bias/M101_BIAS_Tv14000s_800iso_00104_20171001-16h43m55s019ms.CR2
   25 :     26820   0.149% (     1518 +     25302 =   0.008% +   0.140%)
   26 :     26719   0.148% (     1532 +     25187 =   0.008% +   0.140%)
   27 :     27200   0.151% (     1479 +     25721 =   0.008% +   0.143%)
E:/M101/Bias/M101_BIAS_Tv14000s_800iso_00106_20171001-16h46m21s981ms.CR2
   28 :     26592   0.148% (     1529 +     25063 =   0.008% +   0.139%)
E:/M101/Bias/M101_BIAS_Tv14000s_800iso_00108_20171001-16h44m14s206ms.CR2
   29 :     26433   0.147% (     1592 +     24841 =   0.009% +   0.138%)
E:/M101/Bias/M101_BIAS_Tv14000s_800iso_00108_20171001-16h47m41s379ms.CR2
   30 :     27778   0.154% (     1526 +     26252 =   0.008% +   0.146%)
E:/M101/Bias/_MG_0098.CR2
   31 :     23656   0.131% (     1609 +     22047 =   0.009% +   0.122%)
   32 :     26477   0.147% (     1504 +     24973 =   0.008% +   0.139%)
   33 :     27529   0.153% (     1527 +     26002 =   0.008% +   0.144%)
   34 :     25939   0.144% (     1505 +     24434 =   0.008% +   0.136%)
   35 :     26770   0.149% (     1583 +     25187 =   0.009% +   0.140%)
   36 :     24328   0.135% (     1550 +     22778 =   0.009% +   0.126%)
   37 :     24103   0.134% (     1555 +     22548 =   0.009% +   0.125%)
   38 :     25808   0.143% (     1519 +     24289 =   0.008% +   0.135%)
   39 :     27420   0.152% (     1539 +     25881 =   0.009% +   0.144%)
   40 :     25065   0.139% (     1501 +     23564 =   0.008% +   0.131%)
Total :   1060945   0.147% (    61564 +    999381 =   0.009% +   0.13done
45.714 s
* End integration of bias frames
* Writing master bias frame:
E:/M101/master/bias-BINNING_1.xisf
Writing image 'integration': w=5202 h=3465 n=1 Gray Float32
182 FITS keyword(s) embedded.
Writing image 'rejection_low': w=5202 h=3465 n=1 Gray Float32
Writing image 'rejection_high': w=5202 h=3465 n=1 Gray Float32
* Begin integration of dark frames
ImageIntegration: Global context
Opening files:
E:/M101/Dark/DARK_420s_800iso_+70f_2012042417h38m01s059.CR2
Timestamp ........ 2012-04-25T00:31:15Z
Exposure ......... 420s
* Incremental image integration disabled due to lack of file format support: RAW
Converting to RGB:   0%
Weight          :     1.00000
* Using 8 worker threads.
[000] E:/M101/Dark/DARK_420s_800iso_+72f_2012042417h00m43s279.CR2
[001] E:/M101/Dark/DARK_420s_800iso_+72f_2012042417h52m21s622.CR2
[002] E:/M101/Dark/DARK_420s_800iso_+72f_2012042417h59m31s046.CR2
[003] E:/M101/Dark/DARK_420s_800iso_+72f_2012042418h06m40s882.CR2
[004] E:/M101/Dark/DARK_420s_800iso_+72f_2012042714h01m21s142.CR2
[005] E:/M101/Dark/DARK_420s_800iso_+72f_2012042714h22m35s639.CR2
[006] E:/M101/Dark/DARK_420s_800iso_+72f_2012042714h29m40s051.CR2
[007] E:/M101/Dark/DARK_420s_800iso_+73f_2012042417h45m11s815.CR2
Timestamp ........ 2012-04-24T23:53:56Z
Converting to RGB:
Weight          :     1.00000
[000] E:/M101/Dark/DARK_420s_800iso_+73f_2012042714h08m26s421.CR2
Timestamp ........ 2012-04-25T00:45:35Z
Converting to RGB:
Weight          :     1.00000
[001] E:/M101/Dark/DARK_420s_800iso_+73f_2012042714h15m31s155.CR2
Timestamp ........ 2012-04-25T00:52:45Z
Converting to RGB:
Weight          :     1.00000
[002] E:/M101/Dark/DARK_420s_800iso_+75f_2012042417h29m25s200.CR2
Timestamp ........ 2012-04-25T00:59:55Z
Converting to RGB:
Weight          :     1.00000
[003] E:/M101/Dark/DARK_420s_800iso_+75f_2012042713h30m25s345.CR2
Timestamp ........ 2012-04-27T20:54:37Z
Converting to RGB:
Weight          :     1.00000
[004] E:/M101/Dark/DARK_420s_800iso_+77f_2012042417h22m14s567.CR2
Timestamp ........ 2012-04-27T21:15:53Z
Converting to RGB:
Weight          :     1.00000
[005] E:/M101/Dark/DARK_420s_800iso_+79f_2012042417h15m03s933.CR2
Timestamp ........ 2012-04-27T21:22:57Z
Converting to RGB:
Weight          :     1.00000
[006] E:/M101/Dark/DARK_420s_800iso_+81f_2012042417h07m53s458.CR2
Timestamp ........ 2012-04-25T00:38:25Z
Converting to RGB:
Weight          :     1.00000
[007] E:/M101/Dark/DARK_420s_800iso_+81f_2012042713h44m46s116.CR2
Timestamp ........ 2012-04-27T21:08:48Z
Converting to RGB:
Weight          :     1.00000
[001] E:/M101/Dark/DARK_420s_800iso_+81f_2012042713h51m55s577.CR2
Timestamp ........ 2012-04-25T00:22:38Z
Converting to RGB:
Weight          :     1.00000
[002] E:/M101/Dark/DARK_420s_800iso_+82f_2012042713h37m35s851.CR2
Timestamp ........ 2012-04-27T20:23:40Z
Converting to RGB:
Weight          :     1.00000
[003] E:/M101/Dark/DARK_420s_800iso_+95f_2012042220h08m36s986.CR2
Timestamp ........ 2012-04-25T00:01:06Z
Converting to RGB:
Weight          :     1.00000
Timestamp ........ 2012-04-27T20:38:01Z
Converting to RGB:
Weight          :     1.00000
Timestamp ........ 2012-04-27T21:01:43Z
Converting to RGB:
Weight          :     1.00000
Timestamp ........ 2012-04-27T20:45:12Z
Reading RAW data:
*** Error: LibRaw (-100009): Input/output error
Timestamp ........ 2012-04-25T00:15:27Z
Converting to RGB:
Weight          :     1.00000
Timestamp ........ 2012-04-25T00:08:17Z
Converting to RGB:
Weight          :     1.00000
Timestamp ........ 2012-04-27T20:30:51Z
Converting to RGB:
Weight          :     1.00000
Timestamp ........ 2012-04-23T03:01:48Z
Converting to RGB:
Weight          :     1.00000
Integration of 20 images:
* Using 637 concurrent pixel stack(s) = 1023.89 MiB
*** PCL Win32 System Exception: At address 000007FEFCC7BDED with exception code C0000005 :
Access violation: invalid memory read operation at address 0000000000000000
<* failed *>
* End integration of dark frames
************************************************************Auto crop ................. enabled
Converting to RGB:
Weight          :     1.00000
Converting to RGB:
Weight          :     1.00000
Converting to RGB:
Weight          :     1.00000
Converting to RGB:
Weight          :     1.00000
Converting to RGB:
Weight          :     1.00000
Converting to RGB:
Weight          :     1.00000
Converting to RGB:
Weight          :     1.00000
Converting to RGB:
Weight          :     1.00000
Converting to RGB:
Weight          :     1.00000
Converting to RGB:
Weight          :     1.00000
Converting to RGB:
Weight          :     1.00000
Converting to RGB:
Weight          :     1.00000
45.714 s
Opening files:
Weight          :     1.00000
Converting to RGB:
Weight          :     1.00000
Converting to RGB:
Weight          :     1.00000
Converting to RGB:
Weight          :     1.00000
Converting to RGB:
Weight          :     1.00000
Converting to RGB:
Weight          :     1.00000
Converting to RGB:
Weight          :     1.00000
Converting to RGB:
Weight          :     1.00000
Converting to RGB:
Weight          :     1.00000
Converting to RGB:
Weight          :     1.00000
Converting to RGB:
Weight          :     1.00000
Converting to RGB:
Weight          :     1.00000
Converting to RGB:
Weight          :     1.00000
Converting to RGB:
Weight          :     1.00000
Converting to RGB:
Weight          :     1.00000
Reading RAW data:
Converting to RGB:
Weight          :     1.00000
Converting to RGB:
Weight          :     1.00000
Converting to RGB:
Weight          :     1.00000
Converting to RGB:
Weight          :     1.00000
<* failed *>
« Last Edit: 2019 January 06 22:17:40 by jimwaters »
Offline jimwaters
Re: PCL Win32 System Exception: At address ... LibRAW Error
« Reply #1 on: 2019 January 06 20:40:08 »
I removed the "DARK_420s_800iso_+81f_2012042713h51m55s577" sub and BPP runs to completion.  When I used Digital Photo Professional to look at the subs last week they looked OK.  When I try to open the above sub with Digital Photo Professional now it display's a Question Mark in the image window.  Now sure what happened.
It looks like there's no LibRAW Error.
« Reply #2 on: 2019 January 11 07:44:25 »
In the last paragraph of your post - what is the file extension on the file being opened?
In other words, what type of image do 'you' think it is, compared to the image type that DPP believes it to be (although it seems to be an image type the DPP cannot 'understand' and hence cannot open), compared to the image type that your Operating System may or may not be able to understand, compared to the image type that PixInsight may (indeed, should) be able to open?
The 'devil is in the detail' here - that file extension is a crucial piece of information, and you really should have the display of all file extensions 'enabled' within your OS, and should really be quoting the extension in the file name whenever you refer to any file. A filename without a file extension is not really a filename at all.
« Reply #3 on: 2019 January 11 10:56:02 »
using control-s:
