Author Topic: PI ICON  (Read 1309 times)
Offline francesco
PI ICON
« on: 2019 January 04 02:58:19 »
Good morning and happy new year to all.
Aftter some applications of new version, all typical PI icons ( for the various files) have been replaced by a rectangular withe shape with a small green area inside and no any more the typical blue cube...
Can you help me?
Francesco
Re: PI ICON
« Reply #1 on: 2019 January 04 06:17:10 »
Hi Francesco,
It would seem that your Operating System (Windows?) has lost all PixInsight file-type associations.
Perhaps you could attach a detailed screen-grab of one of the icons in question and someone might be able to suggest a remedy.
Offline francesco
Re: PI ICON
« Reply #2 on: 2019 January 04 06:30:35 »
Hi Niall
thanks for quick reply .
here attached the screenshot
thanks for support
Best regards
Francesco
Re: PI ICON
« Reply #3 on: 2019 January 04 08:04:08 »
Hi Francesco,
OK - I've had a look at your screen capture, but we are still missing a vital piece of information - thefile extension for the file in question.
I'm sorry, but for several years now Microsoft has been dumbing-down their releases of Windows. It would seem that they have no reason to believe that users have any need to see file extensions, and so they turn them off, by default.
You will need to perform a suitable search for yourself to learn how to turn file extensions (for all files) back on. My guess however is that those files that do appear with a thumbnail of the associated image have been saved in a format that Windows can automatically recognise, interpret and display, whilst those 'white-box' icons contain the image data in the best format for PixInsight, and for which Windows is unlikely to ever provide an interpreter.
Further - if you 'double-click' on one of your 'white-box' image icons, this should cause PixInsight to start running (if not already running) and then display the selected image(s). If this does not happen, then you have lost what is called 'file association' whereby Windows, otherwise incapable of doing anything with that particular file type, checks an internal table to see that it has been configured to open files like this, with a certain file extension (that you cuurently cannot see) with a program called PixInsight.
I hope I haven't lost you during my attempts to explain what I believe might be happening - but, if I have, please come back for more hhelp.
Offline francesco
Re: PI ICON
« Reply #4 on: 2019 January 04 08:19:47 »
Hi Niall
many thanks for your detailed explanation.
I can confirm what you wrote me : effectively clicking on the file , PI runs correctly.
They are xisf files ( all files generated during the process)
I thought that something was wrong in windows 8 : so far I decided to REINSTALL Pixinsight and now everything run in proper way.
Myabe some file was corrupted.
But reinstallation was necessary and now it is again OK !
Thanks again for your great support
Best regards and have a good 2019 continuation!!
Francesco
Re: PI ICON
« Reply #5 on: 2019 January 04 08:23:11 »
Hi Francesco,
I am glad you found a solution, and hope that you continue to enjoy PixInsight  :)
Offline acmalko
Re: PI ICON
« Reply #6 on: 2019 January 05 12:57:13 »
I've the same problem regularly, perhaps each time I update Pix.
All is working correctly but the icon is lost. The file association is good. I've ever read such a problem but I think there's no solution yet.
Offline acmalko
Re: PI ICON
« Reply #7 on: 2019 January 20 14:53:34 »
I've just found a solution for me
In regedit, HKEY CLASS ROOT, search
Pleiades Astrophoto.PixInsight.xisf\DefaultIcon
Pleiades Astrophoto.PixInsight.xosm\DefaultIcon
Pleiades Astrophoto.PixInsight.xpsm\DefaultIcon
and change the value to "C:\Program Files\PixInsight\bin\PixInsight.ico" for each one.
Close, restart and enjoy
The value was "C:\Windows\Installer\{89FF21A3-FA74-4ACD-BDCF-8817790F5807}\PixInsight.exe,0"
I don't know if my way is good  so be careful with regedit, save it before and adapt the path if needed.
