Author Topic: New release 1.8.6.1448 , Issues.  (Read 1245 times)
Offline jdelgado3
  • Observatorio Astronómico Ojo de Horus
« on: 2018 December 23 10:54:23 »
Is it me or anybody else is experiencing issues with this last release?
Issues like when doing Debayering the programs shuts off.
I had to run several times pre-process because after Integration the image was blurred like if Star Aligment did not work ?
Hopefully is just me or my laptop.
Offline jdelgado3
Re: New release 1.8.6.1448 , Issues.
« Reply #1 on: 2018 December 24 08:11:04 »
Update, I tried in my PC and tried to Debayer the same data with the same results, when I hit "run" PixInsight screen goes off. The program terminates.
Then on the Debayer dialog I changed the "Bayer/Mosaic pattern" from RGGB ( that I always used ) to auto and the program runs and finish its task.
So, looks like there is a bug in the program.
« Reply #2 on: 2018 December 24 08:20:29 »
We cannot reproduce this problem. Can you please upload a data set where this issue can be reproduced, as well as the sequence of operations necessary to reproduce it? That would be of great help to diagnose and fix it quickly.
Offline jdelgado3
« Reply #3 on: 2018 December 26 07:14:26 »
I will be more than happy to upload the data set as soon as I find how to do it...
Should I load them as attachments ?
« Reply #4 on: 2018 December 26 09:02:16 »
Hi, no, you cannot upload these images as attachments in a forum post. Can you upload a bunch of them (where the problem can be reproduced) to a file sharing service such as Dropbox, or something similar?
Offline jdelgado3
« Reply #5 on: 2018 December 26 14:05:40 »
Here...
https://www.dropbox.com/sh/bytfugbi8pshi8j/AAAWBwOMppTSoarEQcl0-Lona?dl=0
My settings are for RAW selected with ¨Pure Raw¨ and when I run the Debayer process I select RGGB and the issue happens. If I choose Auto, runs ok.
Note, just uploaded half of the subs.
« Reply #6 on: 2018 December 27 08:00:23 »
Thank you so much for uploading these images. I have thoroughly analyzed this problem. It is real and happens on all platforms, although it is much more likely to happen on Windows. It happens irrespective of the Bayer pattern selected, when a relatively large number of RAW frames is selected in the Debayer tool.
This problem is complex and difficult to debug. The error originates in the RAW support module, somewhere within LibRaw's code, and happens when LibRaw is being invoked from a running thread. The reason you didn't find it before is that previous 1.8.5 versions of PixInsight used dcraw as a back-end implementation to support digital camera raw formats, while PixInsight 1.8.6 uses LibRaw.
The bug causes an unavoidable application termination as a result of a series of successive critical errors, which leave the code involved in an unstable state that cannot be recovered. That being said, the practical importance of this bug is very limited. The Debayer tool should not be used to demosaic raw frames from digital cameras directly. It is intended to be used on already calibrated frames, which should be in XISF format. Of course, there are no problems at all when you use XISF images with the Debayer tool, since the XISF implementation is fully thread-safe.
So the workaround to this problem is simply to use it as it is intended to be used: with calibrated frames in XISF format. If you don't want to input calibrated frames, you can use the BatchFormatConversion script to convert your ARW files to XISF files, then feed the Debayer tool with them.
Again thank you for detecting this issue. At any rate, I'll try to fix it as soon as possible.
Offline jdelgado3
« Reply #7 on: 2018 December 27 10:07:54 »
Thanks a lot Juan for your quick response on this.
I will take note of that on my personal workflow for my ARW/RAW files.
Saludos !
