Author Topic: When to Use CosmeticCorrection During DSLR Processing?  (Read 1989 times)
Offline jimwaters
« on: 2018 December 19 22:39:47 »
For 'manually' processing, aligning and stacking DSLR images when should I run CosmeticCorrection?
After ImageCalibration and before Debayer?
Offline RickS
Re: When to Use CosmeticCorrection During DSLR Processing?
« Reply #1 on: 2018 December 19 23:34:00 »
Yes, that's correct.
Offline John_Gill
« Reply #2 on: 2018 December 19 23:45:20 »
With "Lights" you start with Blink ---> ImageCalibration ---> CosmeticCorrection ---> Debayer ---> SubframeSelector ---> CanonBanding(optional- can be done later in the workflow) ---> StarAlignment ---> LocalNormalization ---> ImageIntegration ---> DrizzleIntegration(only if data was generated in StarAlignment earlier)
space is not black
John
APM 107/700 apo on CGX mount
ZWO Optics - Autoguiding
ZWO1600mm and filters
« Reply #3 on: 2018 December 20 02:18:47 »
And, then again . . .
If you do anything that modifies the relationship between the CFA and the pixel field, wouldn't this have a detrimental effect on the DeBayered data - one that could well require a second round of cosmetic correction later in processing?
Wouldn't a  :-\ better  :-\ approach be to perform all the calibration, deBayering, registration amd rejection-based integration steps first - and then to inspect the resultant MasterLight to see if cosmetic correction would have been necessary?
I don't know the answer because I don't use a DSLR and therefore have no experience as to why DLSR images would require cosmetic correction where other OSC cameras do not (for example, I have never needed to use this process).
Perhaps the only way to answer the question would be to pre-process the same set of raw data in two different ways, and then see what the outcome is?
