Author Topic: Exact Steps BatchPreProcessing Script Takes...?  (Read 1776 times)
Offline jimwaters
« on: 2018 December 15 18:59:43 »
Does anybody know the exact steps the BPP Script takes?  Is this documented anywhere?  Thx
Offline RickS
Re: Exact Steps BatchPreProcessing Script Takes...?
« Reply #1 on: 2018 December 15 19:39:51 »
Jim,
I don't know of any documentation with exact and up to date details.  You can get some of this from the parameters in the script dialogs and process console output.  For the rest you'd probably need to read the source code.
Rick.
Offline jimwaters
« Reply #2 on: 2018 December 15 20:09:35 »
What I am trying to find out if just Flats are normalized against BIAS or both Flats and Darks are done from a DSLR standpoint.
« Reply #3 on: 2018 December 15 20:51:15 »
if you look at one of the calibrated flat subs, the fits header should show the ImageCalibration history including what types of calibration frames were applied and what the calibration filenames were.
Offline jimwaters
« Reply #4 on: 2018 December 15 21:06:04 »
Rob - Thanks.  It only looks like Flats are calibrated when using BPP.
Some on the internet say both Flats and Darks should be calibrated. They didn't make a distinction between DSLR, OSC or Mono CMOS / CCD.
Offline RickS
« Reply #5 on: 2018 December 15 21:40:23 »
BPP creates a master dark that isn't bias calibrated but can calibrate the master dark with the master bias on the fly when calibrating light frames (see the Calibrate box under Master Dark in the ImageCalibration dialog.
Offline jimwaters
« Reply #6 on: 2018 December 15 23:17:01 »
Just saw it a few minutes ago.  Many thanks.
