Author Topic: CloneStamp 255 Pixel Limit?  (Read 1789 times)
Offline GaryI
« on: 2018 December 11 21:32:52 »
The maximum radius for CloneStamp is 255 pixels.  I have a few occasions where a radius of a bit more than that would be very helpful.  Are there any tricks to be able to enlarge the radious beyond 255 pixels?
Re: CloneStamp 255 Pixel Limit?
« Reply #1 on: 2018 December 11 22:04:00 »
Hi Gary,
Perhaps you could explain the scenario where you need to be able to run CloneStamp at a radius greater than 255 pixels?
That may help us to better understand your issue(s) and offer suggestions.
Offline GJL
« Reply #2 on: 2018 December 12 01:48:13 »
For example if you want to remove all other objects around a central object (galaxy) in a mask and use a black or white auxiliary image.
Gerhard
« Reply #3 on: 2018 December 12 03:33:43 »
Gerhard
I would just use the RangeSelection tool. Here I use the tool twice to achieve that type of result. You can very the parameters to fine tune your results. The second screen shot shows making a mask where everything above a level of .22 is captured with no smoothing. I would use something like this if I had issues with my background.
I'm not saying I haven't used Clone stamp with a large pixel radius but for most image problems I find other tools in PI to be much more precise and much quicker.
Offline GJL
« Reply #4 on: 2018 December 12 09:37:28 »
Thank you, Mike.
I know RangeSelection, of course. I'll try using it twice. Another solution in this special case would be to use a mask with the Script Game.
Gerhard
« Reply #5 on: 2018 December 12 10:06:00 »
Gerhard
One more way of making a mask is with MT. I like using it because it's not grayscale or binary. Of course you can then make a secondary mask from there.
Offline GJL
« Reply #6 on: 2018 December 13 00:51:18 »
Very interesting way to remove the stars in the mask. I didn't know yet.
Gerhard
Offline GaryI
« Reply #7 on: 2018 December 13 12:46:28 »
Niall Saunders,
My sensor is 4600x3500, so there are a few occasions that I would like to correct bright star halos or even large faint dust motes.  Sometimes vignetting in the corners.  The attached image is an example that brought this to mind again - the halo from Eta Geminorum while imaging IC443.
I have been using masks to handle these over the past few years, it just would be much easier to have a CloneStamp limit of 510 instead of 255.
Gary
