Author Topic: Manual Integration, Alignment, Stacking 'Wide-Field' vs. 'Deep Sky' Images  (Read 1586 times)
Offline jimwaters
I image wide-field (<200mm) and DSO (>800mm) objects and process the images with PI using the same basic parameters.  I always take Darks, Flats and BIAS subs and until recently I used the BatchPreProcessing script.  I recently started processing my images manually and generally use the recommended default values for ImageIntegration, ImageCalibration, StarAlignment …etc.
My question is, should I use different default values / entries for the above processes when I do Wide-Field vs. Deep Sky imaging?
I image with a modified Canon 6D.
Offline John_Gill
Hi Jim,
I used an standard Canon 600D and I use the same or very similar setting for wide-field and for DSO's pre and post processing.
space is not black
John
APM 107/700 apo on CGX mount
ZWO Optics - Autoguiding
ZWO1600mm and filters
