Author Topic: Help - PI app will not load after installing on Linux Mint  (Read 1633 times)
Offline photonhunter1
Help. Pixinsight will not load after following the Linux installation instructions. I have PI installed on my iMac but built a desktop specifically for PI so this install would be my second (keeping the app on the Mac as well). Here's what I did:
1) I copied the pixinsight-license file from my Mac and placed it in my /home/mike directory. The file name does not contain the preceding leading dot character.
2) I logged into PI software distribution and downloaded the Linux tar file
3) I then created a "pi-install" directory in /home/mike and moved the .tar file to the /home/mike/pi-install directory
4) I then proceeded to follow the "tar -xzf" command as listed on PI installation notes
5) I then ran the "sudo ./installer" command and typed "yes" to installing PI. Below is the output from my terminal window:
PixInsight X11 UNIX/Linux installer version 01.08.05.1352 Ripley
Copyright (C) 2003-2017 Pleiades Astrophoto. All Rights Reserved
PixInsight will be installed with the following parameters:
Source installation directory ... /home/mike/pi-install/PixInsight
PixInsight core application ..... /opt/PixInsight
Application desktop entry ....... /usr/share/applications/PixInsight.desktop
Application icons directory ..... /usr/share/icons/hicolor
MIME type description file ...... /usr/share/mime/packages/PixInsight.xml
Create /bin launcher script ..... yes
Remove previous installation .... yes
==> Are you sure [yes|no] ? yes
Please wait while PixInsight is being installed...
* Previous PixInsight installation removed.
* PixInsight installation completed.
I went into the Linux Mint menu, All Applications, and selected the Pixinsight icon. The application did not load.
I typed PixInsight in my terminal and received the following message:
/opt/PixInsight/bin/PixInsight: /opt/PixInsight/bin/lib/libz.so.1: version `ZLIB_1.2.9' not found (required by /usr/lib/x86_64-linux-gnu/libpng16.so.16)
What am I missing? Help...
« Last Edit: 2018 November 21 18:32:56 by mijoschille »
Re: Help - PI app will not load after installing on Linux Mint
« Reply #1 on: 2018 November 21 18:35:51 »
Problem solved via this post:
https://pixinsight.com/forum/index.php?topic=10718.msg73345#msg73345
Thank you AdirondackAstro!
