Author Topic: BPP - Batch Preprocessing - Final Stack Summary?  (Read 1656 times)
Offline Rolkol
« on: 2018 November 20 01:15:08 »
Hi Guys,
Is there any way to find out the summary of the final stack?
Like total integrated time, amount of subs and etc?
Something like DSS or ASTAP does
Offline bulrichl
Re: BPP - Batch Preprocessing - Final Stack Summary?
« Reply #1 on: 2018 November 20 02:35:08 »
In the detailed output directly after termination of the integration process there is (outputted to the Pocess Console) indicated the number of images.
Also when you open the integration file and execute Image/FITSHeader, you will find the value of 'ImageIntegration.numberOfImages' as well as the parameters used for the integration process and scale, location and noise estimates, image weight, scale factor, zero offset, rejected low and rejected high pixel numbers for each subframe. However there is no information about subframe exposure time or total exposure time.
Bernd
Offline Rolkol
« Reply #2 on: 2018 November 20 03:19:23 »
How sad...
Sometimes, with subs from different sessions, stack becomes a bit large and with different exp time and etc... and if few there rejected and not stacked,
there is no way to calc total integration...
Only, to hope, BPP will stack it ALL 100% and calc manually...
