Author Topic: Does PhotometricColorCalibration work with Drizzle Integrated pictures?  (Read 2194 times)
Offline akoenig
I can get PhotometricColorCalibration to work with normally integrated Pictures, but the process allways Fails when I try it on Drizzle Integrated Pictures. Can anyone help?
Thanks.
Allen
it may be that you need to change the pixel scale if you are using PCC to solve the image. in other words, if your undrizzled pixel scale is 1 arcseconds per pixel and you drizzle 2x, the drizzled image has a pixel scale of 0.5 arcseconds per pixel.
Offline akoenig
Hi Rob,
thank you for your Response. You're absolutely correct. It works now.
Thanks.
Allen
