The workflow that I use consists of Lights, Darks that match the lights exactly (time, temperature, gain, offset), Flats and Dark Flats (that match the flats exactly). I don't use bias frames, since the bias is already in the other frames. With cmos that has amp glow, you can't use optimised or scaled darks, because the glow is non linear.
I have an ASI174MM-Cool, that has considerably more amp glow than the ASI1600.
Hope this helps.
