Author Topic: What's going on here? Convolution, STF, then undo convolution  (Read 1654 times)
Offline carl
Hi folks,
I'm doing a particular project using SDSS data trying to detect faint tidal streams. I've discovered that the following process shows them up, but I don't understand what's actually happening in PI terms.
1. Convolution (gaussian, 7SD)
2. STF AutoStretch (Boosted)
3. Undo convolution
Ideally, I'd like to automate this entire process so is it possible to "undo" a convolution in a process container or JavaScript or something?
Secondly, can someone explain how the undo works after the STF has been run?
C.
Offline RickS
Re: What's going on here? Convolution, STF, then undo convolution
« Reply #1 on: 2018 October 15 19:51:25 »
All you are doing is applying a stronger screen stretch to the data.  STF calculates the autostretch on the basis of the smoothed data then you undo the convolution and keep the stretch.  The screen stretch doesn't get undone because it didn't actually modify the image data - only the parameters used to display it.
Offline carl
« Reply #2 on: 2018 October 15 23:01:16 »
Thanks Rick. I thought it might be something like that.
Is there a way to script the "undo convolution"? I would like to automate this process over a few hundred images.
Offline RickS
« Reply #3 on: 2018 October 15 23:28:37 »
Hi Carl,
I expect it is possible to do this in Javascript but you can probably get a similar effect by adjusting the STF autostretch parameters for a more aggressive stretch without the need to convolve/undo.  Ctrl-left click on the STF "radioactive" icon to find the autostretch parameters.
Rick.
