Author Topic: Mosaic issue--Star Alignment  (Read 2389 times)
Offline alanrock
« on: 2018 September 13 10:19:00 »
I have a six panel Mosaic that I am trying to assemble. The first three panels aligned properly, but for some reason I cannot get the other panels to align. It's a very busy part of the sky--lots of stars to choose from (maybe too many?) Any suggestions? Here's the tail end of the log from the process console:
* Reference image: Limiting to 8000 brightest stars.
Matching stars: done
2132 putative star pair matches.
Performing RANSAC: done
* Previous attempt failed - this is try #24
useScaleDifferences=true
1642 putative star pair matches.
*** Error: Unable to find an initial set of putative star pair matches
<* failed *>
« Last Edit: 2018 September 14 13:22:50 by alanrock »
Re: Mosaic issue--Star Alignment
« Reply #1 on: 2018 September 13 12:05:27 »
you can make previews over the parts of the mosaic and the part of the pane that you expect to overlap to help with this issue.
Offline chris.bailey
« Reply #2 on: 2018 September 13 14:34:15 »
Once you get past four panels building the mosaic with star alignment does get more and more hit and miss, especially with wider fields of view. The MosaicByCordinates and GradienMergeMosaic is more certain of success.
« Reply #3 on: 2018 September 13 17:44:06 »
yep i agree with that, i only use MBC and GMM now for these purposes...
Offline alanrock
« Reply #4 on: 2018 September 13 17:59:48 »
I've never heard of either of those--any tips on use?
Offline alanrock
« Reply #5 on: 2018 September 13 18:30:37 »
When I try using ImageSolver, I get this:
Downloading Vizier data:
http://www.ukirt.hawaii.edu/viz-bin/asu-tsv?-source=I/259/tyc2&-c=314.179921 44.031400&-c.r=1.679454&-c.u=deg&-out.form=|&-out.max=200000&-out=TYC1&-out=TYC2&-out=TYC3&-out=RAmdeg&-out=DEmdeg&-out=pmRA&-out=pmDE&-out=VTmag&-out=BTmag&-out=HIP&VTmag=<13.65
 *** Error: response code = 302
« Reply #6 on: 2018 September 13 21:33:47 »
try choosing a different server... (the orange cylinder next to the catalog chooser). i have mine set to the default which seems to be the server in france.
Offline alanrock
« Reply #7 on: 2018 September 14 11:45:36 »
It fails with the error "This projection is undefined"
« Reply #8 on: 2018 September 14 12:48:33 »
upload the image
Offline alanrock
Offline Andres.Pozo
« Reply #10 on: 2018 September 14 15:51:06 »
The image solves without problems using the default parameters. I only had to estimate the pixel size of your camera (2.4um) since it is not in the FITS header.
Image Plate Solver script version 5.1
Referentiation Matrix (Gnomonic projection = Matrix * Coords[x,y]):
           +5.15681e-06         +0.00025507           -0.482524
           -0.000255033        +5.16292e-06           +0.691295
                     +0                  +0                  +1
Projection origin.. [2747.847349 1836.196702]px -> [RA:20 56 35.500 Dec:+44 47 08.86]
Spline order ...... 2
Num. ControlPoints. 89
Resolution ........ 0.918 arcsec/px
Rotation .......... -91.163 deg
Focal ............. 539.04 mm
Pixel size ........ 2.40 um
Field of view ..... 1d 24' 7.4" x 56' 12.3"
Image center ...... RA: 20 56 35.484  Dec: +44 47 08.72
Image bounds:
   top-left ....... RA: 20 53 50.454  Dec: +45 28 28.72
   top-right ...... RA: 20 54 03.909  Dec: +44 04 26.53
   bottom-left .... RA: 20 59 10.897  Dec: +45 29 37.88
   bottom-right ... RA: 20 59 16.656  Dec: +44 05 31.63
Offline alanrock
« Reply #11 on: 2018 September 14 15:57:53 »
I still get the same issue, and I have left all the parameters at the defaults.
« Reply #12 on: 2018 September 14 16:09:55 »
You might try reseting ImageSolver first. It solved for me also using the same 2.4 pixel size as Andres.
Offline alanrock
« Reply #13 on: 2018 September 14 16:20:49 »
That worked! I certainly don't remember having changed anything in there, but it's possible. Thanks guys!
« Reply #14 on: 2018 September 14 19:06:07 »
Glad things are working again.
