Author Topic: Size difference....  (Read 1758 times)
Offline krphotogs
Size difference....
« on: 2018 September 08 10:49:24 »
I am pretty much a newbie - but after the last few weeks am light years ahead of where I started with PI - but still on the outside looking in...
I am running v 1.8 on a windows machine and an iMac. When I create a master bias on my Windows machine, it creates a master file that is 5599 x 3728. When I create it on my iMac I get one that is 5600 x 3728. Now, I used my windows machine to make some library files (dark's and bias) but I do all my image processing on my iMac.
I have been getting an error that says "incompatible image geometry' which I assume is because of the pixel size difference.
First question is why is that happening? Second question... any fix short of redoing the masters on my iMac?
Kevin
Offline krphotogs
Re: Size difference....
« Reply #1 on: 2018 September 08 11:30:09 »
Ok - just to add some more data.... I tried creating a bias master on my macbook and the size is the same as the Windows machine. When I check the Format Explorer, on my iMac there is no 'DSLR-RAW' (both windows and macbook) only a 'RAW'. I de-installed on my iMac and re-installed, no difference.
Kevin
« Reply #2 on: 2018 September 08 12:46:18 »
Kevin
Incompatible geometry can be the number of channels. If one image is gray scale it has one channel and another is RGB it would have 3 channels and you use a tool that is expecting like number of channels you will get that error.
Offline krphotogs
« Reply #3 on: 2018 September 08 14:23:24 »
Thanks Mike. The problem I had was a difference between the DSLR_RAW and RAW import.
It seems the RAW module created an image that was 1 pixel wider, and that was causing the error I had. I ended up deleting PI from my OS X machines and re-installing PI. When I did a check for updates, both machines (iMac and MB) had the DSLR_RAW module. When I did an ImageIntegration on the same files (previously done with RAW) with the DSLR_RAW module it worked; I then tried with previous created FITS file with the RAW module - it failed.
Thanks for the reply!
« Reply #4 on: 2018 September 08 14:57:21 »
Kevin
That's totally possible since the Raw and DSLR_Raw are 2 different module for opening OSC/DSLR formats. The Raw module though has to be installed/updated by the user. If I'm not mistaken it is not part of the normal update process as of right now. https://pixinsight.com/forum/index.php?topic=12126.0
If you were having problems with a particular camera and installed the Raw module to correct the problem then going back to the DSLR_Raw module will cause the problem to show again. The answer to that would be to install the Raw module on all your PI installations. That is purely a personal decision for now. I would guess(purely speculation) in the next major update the DSLR_Raw module will be completely depreciated and removed in favor of the new Raw module. I don't remember seeing anyone having major issues with the Raw module as compared to many having issues with the old DSLR_Raw module.
Offline krphotogs
« Reply #5 on: 2018 September 08 17:30:47 »
That makes a lot of sense, I did go through and made sure it was on all 3 machines I use. I had trouble on my iMac - when I checked for installed processes, it said it was, but it was not showing up. So, I just deleted and re-added PI.
Thanks again for your help!
Kevin
