Author Topic: Newbie - how come I get black contrasty images after a calibate?  (Read 1713 times)
Offline Ron Kramer
Sometimes I'll try to calibrate say  (all Ha subs). Afterwards when I try to stack it says no data (blank?) when I look at them they are a contrasty
BLACK background and a few WHITE stars (only the brightest). Clicking the stretch button makes no change!   Any idea why?
Offline Geoff
Re: Newbie - how come I get black contrasty images after a calibate?
« Reply #1 on: 2018 September 01 13:21:30 »
Just a guess, but was the master dark made in a different application and not PixInsight?
Don't panic! (Douglas Adams)
Offline Ron Kramer
« Reply #2 on: 2018 September 01 16:51:10 »
I don't recall.  I think it was PI.
Offline RickS
« Reply #3 on: 2018 September 01 18:08:55 »
As Geoff suggested, sounds like a problem with your master dark. Compare statistics (Statistics process) for a couple of your lights and your master dark.  The median value in the lights should be more than in the darks.  If it isn't, when you calibrate with the dark you'll end up with zero values where there isn't much signal in the lights.
If the darks are the problem then next you have to figure out why they don't match...  You could also try setting a pedestal in ImageCalibration as a workaround.
Rick.
