Author Topic: Sony A7III bulb mode images not opening correctly  (Read 1243 times)
Offline RT--
« on: 2018 August 26 10:36:07 »
Hello,
I am having trouble opening Sony ILCE-7M3 bulb exposures in PixInsight.
Have a look at the attached image.
The left one is a 20s exposure shot in manual mode, the right one is a 4min exposure shot in bulb mode.
I have tried a number of different images, and it seems nothing shot in bulb mode will open correctly in PixInsight.
Other software will open the files without issues.
Offline sharkmelley
Re: Sony A7III bulb mode images not opening correctly
« Reply #1 on: 2018 August 26 12:27:29 »
In bulb mode Sony drops the bit depth to 12bits.  But I don't know why that should cause any issues.
Does this problem happen both with compressed and uncompressed file formats?
Can you upload a raw file somewhere e.g. DSC3305.ARW so we can take a look.
Mark
Takahashi Epsilon 180ED
H-alpha modified Sony A7S
Offline RT--
« Reply #2 on: 2018 August 26 12:31:53 »
The 12-bit drop was the first thing on my mind too.
I don't shoot compressed.
I will upload the raw when I get home.
Offline oldwexi
    • Astronomy Pages G.W.
« Reply #3 on: 2018 August 26 12:32:08 »
Some cameras need in Bulb mode 2 times pressing the exposure button.
First press for moving the mirror up and
second press for starting exposure.
It could be that your 4 minute image is only a very short dark image.
Have you checked the header about exposure time?
On the other hand you say image _DSC3305 can be opened by other software AND shows details
of the milkyway ?
Please check what you did.
Gerald
« Reply #4 on: 2018 August 26 12:42:35 »
Real curious to see the raw for this. I still use the Original Nex-5 and no issue ever in bulb and raw. The 7M3 is mirrorless also, right?
Offline RT--
« Reply #5 on: 2018 August 26 13:57:24 »
I did a quick test set. See the attached image.
All images have the same exposure; 2s f/2.8 ISO100.
top left: uncompressed, manual mode
top right: uncompressed, bulb mode
bottom left: compressed, manual mode
bottom right: compressed, bulb mode
Something strange going on with the uncompressed bulb, here's the raw for that one.
https://drive.google.com/file/d/1AFwsopoLn5GBf3I9FdFY6eEte64SP0Sa/view?usp=sharing
All shots open just fine in Photoshop and RawDigger, etc.
« Last Edit: 2018 August 26 14:18:00 by RT-- »
Offline bulrichl
« Reply #6 on: 2018 August 26 15:08:16 »
This raw image (_DSC7108.ARW) is loaded and displayed correctly with the new RAW module, see attached sreenshot.  I suggest to install the new RAW module, see https://pixinsight.com/forum/index.php?topic=12126.0 .
Bernd
« Reply #7 on: 2018 August 26 15:23:34 »
I can confirms Bernds suggestion. Here is the image with the old DSLR_Raw module and PI 1.8.4 and the image is clearly wrong. Running 1.8.5 and the new module the image is fine.
Offline sharkmelley
« Reply #8 on: 2018 August 26 15:25:11 »
Quote from: bulrichl
Bernd
There is obviously something different about the format used for Bulb mode uncompressed data which DCRaw cannot handle.  I don't know why Sony uses a different format for bulb mode.  DeepStacker cannot handle it either because it also uses DCRaw.
Development work ceased on DCRaw some time ago so as Bernd says, you will need the new module based on LibRaw.
Mark
« Reply #9 on: 2018 August 26 15:29:05 »
An interesting thing is the old sony image converter software from 2012 opens the file fine. Not totally sure it's a sony thing as much as a DCRaw problem as I never updated that software. The top 2 images are of course PI but the bottom is the old converter. Anyway the new LibRaw works.
Offline RT--
« Reply #10 on: 2018 August 26 21:18:06 »
Excellent! Thank you for your help!
