Author Topic: Photometric Colour Calibration does not work anymore  (Read 2102 times)
Offline manu.fonfon
Good evening to everybody
I am facing a strange issue since a couple of days: the photometric colour calibration process does not work anymore. It cannot detect stars in my images (and I can tell you there are!)
Wondering if this was not coming from a particular image, I took one which I processed successfully a few days ago: no way, it does not work!
Another one? No way!
A third one...
Taking my second PC gives me the same negative result again...
Downloading the very last updates did not improve anything.
One last information: I have the permanent licence, not the temporary one
If somebody already experienced this strange issue and found the problem, he would be more than welcome!
Cheers
Emmanuel
Offline RickS
Offline manu.fonfon
Re: Photometric Colour Calibration does not work anymore
« Reply #2 on: 2018 June 12 00:50:27 »
Thanks Rick
That describes roughly what I get myself, although I did implement the june update after having discovered the problem; not before...
But I changed to another server and it did not work either; will try again today
Cheers
Offline RickS
« Reply #3 on: 2018 June 12 01:53:11 »
Hi Emmanuel,
I got the same error last night.  Tonight I planned to change the server but it just worked using the original settings, so this is consistent with a server problem and not a bug in PCC.
Rick.
Offline manu.fonfon
« Reply #4 on: 2018 June 12 08:34:05 »
Indeed, it did not work this morning, but worked perfectly right now!
Thanks Rick
Cheers
Emmanuel
