Author Topic: Sub frame selector help  (Read 1802 times)
Offline cuivenion
« on: 2018 May 30 03:09:00 »
Hi, I'm using this guide:
http://www.lightvortexastronomy.com/tutorial-pre-processing-calibrating-and-stacking-images-in-pixinsight.html#Section5
I'm up to the point of Star Alignment after using the sub frame selector. The problem is I don't know which file to use as the reference file. How do I know which file has been selected by the sub frame selector as having the best weights?
Thanks for any help.
Offline cuivenion
Re: Sub frame selector help
« Reply #1 on: 2018 May 30 05:10:21 »
I ran the subframeselector script again and found the best frame through that. I presume that was the right thing to do.
Offline aworonow
    • Faint Light Photography
« Reply #2 on: 2018 May 30 06:20:46 »
Your instincts are correct. You can use the frame that has the best weight, or the most stars. In fact, if you blink your images and toss any clearly inferior ones, then virtually any abundant-star subframe should do. Probably a frame with abundant stars and simultaneously with small FWHM is even a better choice--but probably over-kill.
Offline John_Gill
« Reply #3 on: 2018 May 30 07:27:23 »
Also look at the SNR value, the higher the better and then at eccentricity (star roundness) and the lower the number the better.
Look up
John
APM 107/700 apo on CGX mount
ZWO Optics - Autoguiding
ZWO1600mm and filters
Offline cuivenion
« Reply #4 on: 2018 May 30 07:30:11 »
Thanks, nice to know I was on the right track. I've started off the weighting equation in the guide as I'm still a relative beginner, but I will experiment with different ones.
