Author Topic: What does this memory error mean?  (Read 1964 times)
Offline joelshort
    • Buckeyestargazer.net
« on: 2018 May 19 11:00:20 »
Can someone tell me what the below error means?  I get this error while trying to integrate 100 bias into a master bias.  Other operations do not result in this error.
Joel Short
www.buckeyestargazer.net
Re: What does this memory error mean?
« Reply #1 on: 2018 May 19 13:35:41 »
well its a classic null pointer dereference, could be caused by all manner of bugs... does PI quit after this? if so there might be some kind of core dump / error report in windows that will show the function that was being executed when the error occurred.
Offline joelshort
« Reply #2 on: 2018 May 19 13:55:03 »
Apparently the problem was that 2 of the 100 bias images were somehow corrupt.  Once I removed those images from the stack it processed correctly.
Joel Short
« Reply #3 on: 2018 May 19 14:16:13 »
interesting, so there must be a corner case in the FITS or XISF handler when dealing with corrupt files.
Offline joelshort
« Reply #4 on: 2018 May 19 14:18:13 »
If you say so... :D
Joel Short
