Author Topic: Noise Evaluation  (Read 2292 times)
Offline AF
Noise Evaluation
« on: 2018 April 14 06:10:20 »
Hi Guys
Just wondering if it's beneficial to evaluate noise at every chance I get throughout the imaging processing chain? Eg, Image calibration, debayering and then again at image integration. Does evaluating noise at each stage provide more info to the subsequent processes?
Andrew
Astro Frontyard
Offline wimvb
    • Wims place
Re: Noise Evaluation
« Reply #1 on: 2018 April 21 02:28:28 »
Imo, no, not needed. Use approprate noise reduction when noise starts to become a problem, ie when it becomes visually annoying. Eg, in the linear state you can use tgvdenoise or mlt. In the nonlinear stage, tgvdenoise, mmt, acdnr.
I normally use nr in lab mode, and not ad rgb. This way I can target luminance noise and chrominance noise more precisely.
Wim
AZ EQ6 GT + EQ3 PRO, SW 150P-DS, SW MN190, ZWO ASI174MM-Cool, Pentax K20D (retired),
SW ST80 + ZWO ASI120MM + Lin_guider
