Author Topic: having difficulty creating flats  (Read 2088 times)
Offline bill
« on: 2018 March 30 07:54:43 »
Hello:
I am really a newbie to PI. I have watched tutorials via the internet, purchased Inside Pixinsight and have been playing with data acquired the other night. I use SGP  flats calib wizard to determine my target ADU (33000). Have captured my flats for each (LRGB) filter.
So I began by creating a Master Bias, Master Dark..no problems there. Saved them
Started with Blink and culled out my bad flats
Ended up with 15 blue flats @.63 sec.
When I calibrate using Image Calib, click on  'GO' I get the following error: APPLYING ERROR POLICY, CONTINUE ON ERROR...INCOMPATIBLE GEOMETRY..NO IMAGE COULD BE CALIBRATED
MY OUTPUT DIRECTORY: Master Bias (checked)  master bias has /master bias/integration.xisf
No Calib checked
Master Dark checked ..input Master Dark /integration.xisf
calib and optimize checked
Master Flat (unchecked)
I am sure it's pilot error on my part, but I have tried this 19 different ways from Sunday and get the same results.
Are my flats too short???
Or should I make a master flat using ALL of my flats (lrgb) (commingled first) then check master flat on the bottom and input the master from all flats???
Thanks for your patience!
Bill
Offline aworonow
    • Faint Light Photography
Re: having difficulty creating flats
« Reply #1 on: 2018 March 30 11:25:56 »
Sounds like you could benefit from a tutorial or two. For a start (where I started), see Harry Page's site: http://harrysastroshed.com/pixinsight/pixinsight%20video%20html/Pixinsighthome.html.
Incompatible geometry often means that the number of pixels in X and Y differ from those in the calibration images.
Offline bill
« Reply #2 on: 2018 March 30 12:51:24 »
Is the geometry problem because my darks and biases were binned 1x1 and flats for rgb were binned 2x2?
« Reply #3 on: 2018 March 30 13:53:45 »
seems likely to me, since the bin 2x2 files have a different geometry than the 1x1
Offline Stu
« Reply #4 on: 2018 March 30 14:43:20 »
You need to reshoot your calibration frames for your binning.
Offline bill
« Reply #5 on: 2018 March 31 06:49:12 »
Thanks for the advice!!!....the more I thought about it last evening, the more that made sense. I was able to calibrate my lum FLATS (at 1x1). Will get back to you later with my attempts!!!!
Bill
Offline MikeOates
« Reply #6 on: 2018 April 03 04:29:48 »
You could also Rescale your master flat to match the bin 1x1 images if you can't retake flats that work. Not ideal but it may save a nights batch of images.
