Author Topic: M42 - LRGB  (Read 1263 times)
Offline rodmichael
    • My SkyBin
M42 - LRGB
« on: 2018 February 22 21:01:39 »
This is my first attempt at M42 (10th month of AP). Image pre- and post-processed in PixInsight.
I used 240 total subframes, 120 at 150s (30 each LRGB) and 120 at 30s.
Imaging System = Celestron 11" RASA, f2.22; QSI683WS; Astrodon Gen2 LRGB filters; SB Paramount MX+ with TPoint Supermodel. Otherwise unguided.
I attempted to do HDR composition to account for overexposure of nebula core. I combined stacked linear RGB images of 30s and 150s to produce a linear HDR RGB image. I did the same thing with the Luminance images (20s and 150s).
I stretched the HDR RGB and Luminance images, each in 2 passes.
I did an LRGB combination using a Luminance Transfer Factor of 50 and a Chrominance Transfer Factor of 40.
I performed Noise Reduction with SCNR (Green) and ACDNR.
All comments, critique, or suggestions welcome.
ASTROGRAPH: Celestron RASA, 11" f=2.22
MOUNT:  SB Paramount MX+
IMAGING CAMERA:  QSI 683WS
FILTERS: Astrodon SHO 5nm and Gen2 LRGB
GUIDING: The SkyX TPoint Supermodel and ProTrack
SOFTWARE:  SkyX Pro, PixInsight
Offline rodmichael
    • My SkyBin
Re: M42 - LRGB
« Reply #1 on: 2018 February 23 14:48:56 »
I think I made a major improvement to the image in an attempt to reduce the brightness of the core.
I went back and simply applied HDRMultiscale Transformation (HDRMT) to the HDR Luminance frame, 6-layers, 1 iteration. This is what I came up with after LRGB combination (no HDRMT to HDR RGB frame). This seems like my very best image of M42 so far.
In addition to having a very clear view of the Trapezium stars, the depth of the nebular structure seems to be much enhanced. And the "skeletal" appearance (as I call it) in some renditions doesn't seem as apparent or overwhelming. A personal taste thing, I suppose.
« Last Edit: 2018 February 23 18:59:22 by rodmichael »
Offline ChoJin
Re: M42 - LRGB
« Reply #2 on: 2018 February 24 04:20:01 »
Hello,
congrats Michael. This target really is a wonder.
I don't have any experience with this target, but did you try/apply deconvolution (after integration and DBE, while still linear)?
NB: it seems to me that your mirrors might benefit from some collimation?
Offline rodmichael
    • My SkyBin
Re: M42 - LRGB
« Reply #3 on: 2018 February 24 09:44:34 »
Hello,
No, I've thought about deconvolution, but my limited experience tells me that deconvolution is usually not a very useful tool, at least for me. I'm guessing that you find my stars a bit bloated (so do I). I haven't really got into star reduction yet. I will probably have to bite the bullet one of these days and start learning those processes that can help with that.
Please tell me what you see that suggests a collimation issue. I've been wondering about that myself.
Thanks!
Offline ChoJin
Re: M42 - LRGB
« Reply #4 on: 2018 February 24 11:08:00 »
for the deconvolution, I thought it could bring more details to the nebulosity. I usually don't mind that much about bloated stars unlike most ppl on this forum ;-)
for the collimation, i'm just curious about why the blooms on medium-sized stars seem to be mostly oriented upward instead of being circular.
