Author Topic: Cannot recombine R G B images, keep getting error msg  (Read 2154 times)
Offline Rudy Pohl
« on: 2018 February 21 15:06:45 »
Hi there:
I'm still pretty new to PI and learning how to do the Linear Fit method for color calibration. I have extracted the L image and the R G and B images and used Statistics to find which has the lowest media value, in my case Green. I do the linear fit method by dragging the triangle from the Green image onto the Blue and then the Red.
However, when I try to recombine these image using the LRGBCombine tool it doesn;t work and an error message pops us which reads:
"LRGBCombination
Cannot execute instance on view 45_NEFs_PI-stacked_copy2_L
Reason: LRGBCombination cannot be executed on grayscale images."
I have clicked various combination of things and clicked the reset button on all tools but no success.
Does anyone have any idea what I might be doing wrong?
Thanks very much,
Rudy
Offline RickS
Re: Cannot recombine R G B images, keep getting error msg
« Reply #1 on: 2018 February 21 18:01:59 »
Are you trying to drag and drop the LRGBCombination new instance triangle onto a grayscale image?  That will generate the error message you mention.  What you need to do is load the R, G and B images (and optionally L) and then click on the round "apply global" icon.
Offline Rudy Pohl
« Reply #2 on: 2018 February 22 02:16:40 »
 Hi Rick,
Yes, that's exactly what I was doing wrong. It now worked the first time. Thanks so much.
Best regards,
Rudy
Offline RickS
« Reply #3 on: 2018 February 22 02:49:46 »
Glad I could help, Rudy!
FYI, there is one other common use case for LRGBCombination that does involve the new instance icon: you can combine a Luminance image with an existing RGB image by selecting the Lum in LRGBCombination (untick the R/G/B) and then dragging and dropping the new instance icon on the RGB image.  I use this very frequently as I usually process Lum and RGB data separately and combine them near the end of processing.
Rick.
Offline Rudy Pohl
« Reply #4 on: 2018 February 22 03:24:54 »
Thanks Rick, I just discovered this very step half an hour ago, works great!
Rudy
