Author Topic: Arcsinh Missing in my PI in OS X  (Read 1381 times)
Offline dugstruble
« on: 2018 February 15 14:14:46 »
Arcsinh is missing in my most update version of PI on my Mac Pro. I tried going to install module. It shows that it's there but greyed out and won't let me install it. Is there another fix for this?
Offline dciobota
Re: Arcsinh Missing in my PI in OS X
« Reply #1 on: 2018 February 24 09:30:42 »
I'm having a somewhat similar issue in Windows.  Arcsinh is showing up as an installed module, but not showing up in any of the process explorer dropdowns, including All.
Offline leemr
« Reply #2 on: 2018 February 26 16:00:22 »
I have a similar problem with PixInsight Core 01.08.05.1352 Ripley (x64) on OSX. Checking for updates shows no updates, but I also have no ArcSinH process. For me it's not present when browsing though.
« Reply #3 on: 2018 February 26 16:57:32 »
browse to the directory containing the module and click OK. what you are doing is identifying the directory with the modules, not trying to pick an individual module.
then click "Search" in the Install Modules dialog
PI should then find the library and let you install it.
« Reply #4 on: 2018 February 27 02:21:52 »
As noted in other thread, this problem is not reproducible on any of our working and testing machines. The update providing the ArcsinhStretch module works on all supported platforms under normal working conditions, so if you are running version 1.8.5 of PixInsight and have installed all updates available, ArcsinhStretch should be available in your PixInsight installation. I suggest reinstalling the application, trying on a different machine, and checking your computer(s) for malwares, virus protection applications, or file management applications that can interfere with PixInsight. On Windows 10, some recent system updates have been causing many problems by erasing and damaging application files.
AFAIK, thousands of users are using the ArcsinhStretch process with version 1.8.5 of PixInsight. Unless you can provide a repeatable pattern to show that this problem happens consistently, these are machine-specific issues. Sorry for not being able to offer more useful help.
Offline leemr
« Reply #5 on: 2018 February 28 00:42:59 »
Reinstalling the application worked for me.
