Author Topic: Problem with DARK and BIAS ADU  (Read 2910 times)
Offline -Amenophis-
    • Mon site internet
« on: 2018 February 07 04:40:54 »
Hello everybody,
I am writing to you about a problem to calibrate my darks.
After doing a masterbias using 100 bias, I made the superbias via the process icon in pixinsight.
When it comes to calibrating DARKS with superbias, I have problems.
Indeed, the bottom of the image is degraded enormously.
The cause ?
the ADU value of my DARKS are lower than the ADU value of the superbias. So, when subtracting superbias, I find myself with a lot of black point ....
After calibration with superbias :
I know there is a way to solve the problem.
Including decreasing the ADU of the superbias.
By cons, I do not know how to reduce this value.
Could you help me on this?
Thanks a lot for your help.
Newton 250/900 - Paramount MyT- Moravian G2-4000 - Filtre ASTRODON LRVB Ha Tru-Balance E-serie GEN2
Pur produit Lorrain
Offline bulrichl
Re: Problem with DARK and BIAS ADU
« Reply #1 on: 2018 February 07 07:15:57 »
Hello Amenophis,
when inspecting the pre-calibrated MasterDark with the Image/Statistics process please uncheck 'Unclipped'. You will then see the fraction of pixels that are NOT clipped in the pre-calibration of the MasterDark (count [%]). Alternatively view the histogram of the pre-calibrated MasterDark with the IntensityTransformations/HistogramTransformation process (you will have to use a horizonal zoom of about 100 or 200): it will be clipped severely. I don't know why some tutorials recommend pre-calibrating the dark frames.
The solution will be, not to pre-calibrate the dark frames or the MasterDark, but to let the calibration of the MasterDark be executed during the light frame calibration process.
Take a look here: https://pixinsight.com/forum/index.php?topic=11968.0
Bernd
Offline -Amenophis-
    • Mon site internet
« Reply #2 on: 2018 February 07 10:01:34 »
Thank you very much for your message.
I will read (and do the translation) to understand  :D
Pur produit Lorrain
