Author Topic: Color images come out black and white  (Read 2774 times)
Offline ttrinko
« on: 2018 January 25 15:10:33 »
I've just started using pixinsight and it seems that for most subjects the final LRGB image looks black and white.  I assume I'm doing something wrong.
I have 4 300s exposures in each of the 4 channels-- L R V B-- and I create 4 integrated images one for each band. SNR in all looks good.
I then combine them which produces a highly green tinted image.  I do DBE and then color calibration and I'm left with an image that looks colorless.
Any thoughts?
Thanks!
Offline dpaul
Re: Color images come out black and white
« Reply #1 on: 2018 January 25 17:34:47 »
I'm a beginner here but presumably you are stretching them first before LRGB combining - that I believe is what you should be doing - works for me!
Hope this helps (if I'm right)
David
Offline RickS
« Reply #2 on: 2018 January 25 20:24:51 »
Have you tried a simple RGB combine without the L?  If the L is much stronger than the colour data then it will wash out the colour.  You could also try a big saturation boost with CurvesTransformation (drag up the pink Sat curve.)  That will show if there's colour there but too unsaturated to see easily.  If you can't figure it out then upload sample files (perhaps a smaller crop) to Dropbox or similar and I'd be happy to take a look.
David: you can use LRGBCombine with linear or non-linear data.  Just don't try to combine linear and non-linear data at the same time.
Offline dpaul
« Reply #3 on: 2018 January 26 15:16:54 »
Hi Rick,
That's interesting - any preference for doing the stretching before or after LRGB combining?
David
Offline RickS
« Reply #4 on: 2018 January 26 16:32:56 »
Hi David, my personal preference is to process Lum and Colour separately and combine near the end, so I always do that final combine with stretched data.  It's also perfectly feasible to combine while linear and I'm sure there are folks that prefer that too.  I don't think either approach is the one true path :)
Rick.
Offline dpaul
« Reply #5 on: 2018 January 27 12:44:29 »
Hi Rick,
I've been stretching each one before combining too. This seems the logical thing to do because each colour may not have the same optimum level of stretch.
David
Offline RickS
« Reply #6 on: 2018 January 27 16:31:50 »
Hi David,
I don't stretch the colour channels individually.  I combine them when linear and then use some method of colour calibration to match the channels (mostly PhotometricColorCalibration these days.)  It's only the Lum and the combined RGB that I process separately and combine later.
Rick.
Offline ttrinko
« Reply #7 on: 2018 January 27 20:29:33 »
Thanks! I've got it working now. I think I was having problems because I wasn't delinerizing the images before LRGB combining
Offline dpaul
« Reply #8 on: 2018 January 28 03:26:12 »
Thanks Rick,
I guess the advantage of stretching the colours 'after combining' means you can colour calibrate the combined result linearly - correct?
David
Offline RickS
« Reply #9 on: 2018 January 28 13:09:42 »
Glad to hear you sorted it out.
[quote author=dpaul link=topic=12087.msg74127#msg74127 date=1517138772
[/quote]
Yes David, if you're going to do accurate colour calibration then it needs to be done while the data is linear.
Offline dpaul
« Reply #10 on: 2018 January 28 14:44:49 »
Thanks Rick
I just started a separate topic but can be answered here!
Once I've done the colour calibration on the combined RGB ''linear'' file, how do I best then combine it with the luminance file.
I did the colour calibration as suggested (looks ok), I then stretched it and tried to combine with a stretched Luminance file but in LRGB combination process, it only ''sees'' the Luminance file.
Help!
David
Offline RickS
« Reply #11 on: 2018 January 28 15:11:18 »
Answered in the other thread...
