I cannot say at the moment if this is an "issue" or not....
When using StarMask if the Large Scale growth is set to 0... then no small scale growth seems to occur regardless of the values I input for compensation and growth amount.
In my case I also unchecked all other options (to be safe) such as aggregate ...etc.
Small scale growth does apparently work if Large Scale is set to 1 or more.
Could someone verify this behavior? (It has been verified by two others by my research so far.)
Is this correct and perhaps not an "issue" since there may be something about growth that requires large scale to be checked? (and basically I just don't understand something)
Otherwise could it be a bug? I am using win10, 64bit, PI v 1.08.05.1353
-adam
