Rob
sRGB IEC61966-2.1 is the common ICC profile used for images posted to the internet but wont give you good results if you send it to a printer,
generally printers will use sRGB or one of the wider gamut's like AdobeRGB if they have the capabilities to do so. sRGB appears to be the most
common from a quick search for printers here in the UK although I have no doubt there will be lots that do the higher quality gamut's.
AdobeRGB ICC profiles are available for download from the Adobe site if you do a Google search, once installed, they will be available in PI's
colour management to pick from.
If you are going this 'Printing' route then it is a must to get a monitor colour calibrator to get you monitors colours, brightness and contrast set up correctly.
I got a 'Colormunki Display' for my monitor. The monitor rendition very closely matches the test print I got back from the printers so I was well happy. Cheap
monitors are probably going to have problems calibrating correctly due to them not being capable of displaying enough colour variations, I had this problem
so I have invested in an ASUS 24 inch ProArt monitor which supports nearly 100% (if not 100%) of sRGB, and, it does gaming very impressively too.
When colour calibrating your monitor, it will end up shockingly dim as most people are so used to having their screens overly bright without realising it, so much
so that I got the ColorMunki to make my screen overly bright at 140 cd/m2 whereas the recommended setting is more like 100 - 120 cd/m2. When I compare my
test image to the screen (image being viewed inside PI) it is clear that the screen rendition is a little brighter due to me forcing the extra brightness so I'm going
to have to go back to the beginning and calibrate my monitor going along with recommended settings and I'm sure I'll be smack on.
It doesn't take long for your eyes to adjust to a monitor which is calibrated correctly and what you see on the screen in PI will be almost exactly what you get back
from the your printers.
Very Satisfying
Paul
