Author Topic: Cropping an image that contains an astrometric solution  (Read 2202 times)
Offline xfred53
« on: 2017 November 25 03:35:48 »
I have a lot of frames (L's, R', G' and B's) already calibrated and registered.
I add all of them at once and define an area so that I can crop them only once, using the DynamicCrop and the ImageContainer.
Everything runs fine.
The only thing is that when running the automatic sequence, it stops at each frame because there is an astrometric solution in it and asks if it can be deleted.
When you have a lot of frames, you have to acknowledge the question a ... lot of time.
Is there a way to avoid this ?
Thank you and best regards.
Francois
Kepler RC 35" with EQ8
Atik 383L+
