Author Topic: ABE generates gray background  (Read 2614 times)
Offline animan
« on: 2017 November 24 17:55:08 »
I can often get into situations where ABE generates a "Gray Background" with equal RGB values. Image inspection of generated background reveals RGB values of around 10.86 in 16-bit numbers on an unstretched image.  This is using a Function degree of 1. If I subtract this background and generate another one, it generates the same gray background again... I can keep going on and on with same result.
My images have a lot of gradients due to light pollution. ABE will initially generate backgrounds to match the gradients and then keeps on generating the Gray backgrounds if re-run. Why are the gray backgrounds being generated and should the gray correction be indeed applied to the image?
Thanks.
Offline RickS
Re: ABE generates gray background
« Reply #1 on: 2017 November 24 21:05:56 »
You would get a grey background when there's no colour cast left.  That would be time to stop...
Offline animan
« Reply #2 on: 2017 November 24 21:49:44 »
Thanks for the response.
Yes, the normal thing would be to stop after ABE starts generating grey background, however, I have noticed that if I continue applying ABE with grey backgrounds, I gradually start to reveal coloration in stars and other subtle detail, it's like peeling layers of an onion. Do you know why this would be?
Also, is there a way I can run a Pixinsight process like ABE in a loop, I would like to experiment to see what I end up with after 500 to 1000 iterations.
Thanks.
Offline RickS
« Reply #3 on: 2017 November 25 04:03:26 »
If you keep removing a pedestal with R=G=B then any differences between the channels would be exaggerated, so I guess that would explain increased coloration.  I have a collection of techniques for increasing colour already so I've never felt the need to do this.
You can write a script but I don't know of any simpler automated way for that many iterations.
Rick.
Offline animan
« Reply #4 on: 2017 November 25 11:39:01 »
Thank you Rick.
