Author Topic: Internal error: MainView::~MainView(): Unexpected shared image reference  (Read 909 times)
Offline Salvatore Giambruno
I was asked by the program to report this, so here it is:
Internal error: MainView::~MainView(): Unexpected shared image reference:
Image112_clone
This denotes corruption of internal data structures. To stay on the safe side, save your data, exit the application, and start again. Please report this problem to our development team.
--Sal
Hi Salvatore,
Thank you for reporting this. This error message has been generated by self-diagnostics code in the PixInsight core application. These problems can only happen under very atypical working conditions. Scarce memory or disk resources are possible causes, especially on Windows. Can you describe the sequence of operations you performed in PixInsight before this happened, or much better, upload an image where this can be reproduced?
Hi Juan,
Sorry, but I have no recollection of the circumstances.  I can say however, that the PC I was using to process is a little light on RAM (12GB), so I suspect you are correct to suspect that a shortage of memory caused the error.  No big deal for now . . . I plan to upgrade my RAM.
Thanks for your help.
Sal
--Sal
