Author Topic: using workspaces  (Read 2421 times)
Offline alcol
using workspaces
« on: 2017 November 03 14:04:30 »
Just started to put imaging files etc into Projects and decided to split data and processing into a number of Workspaces.
My first project involves a 3 part mosaic so I decided to put images for each part in a separate Workspace and renamed them mosaicpart1, mosaicpart2 and mosaicpart3 plus a 4th workspace renamed "masks". Saved the whole lot as a Project.
However, I then set up another project for an LRGB image and set up 2 Workspaces  "Limage" and "RGBimage" and saved it.
When I open either of the projects all 6 Workspaces set up open in the window, albeit only the data relevant to the project opened appear in the relevant Workspace and the others are empty.
I thought opening a Project would only open the Workspaces relevant to it?
Am I missing something?
« Last Edit: 2017 November 04 04:34:20 by alcol »
Re: using workspaces
« Reply #1 on: 2017 November 04 07:38:27 »
I believe Workspaces are a system level setting not project only like the tool bars.
Offline alcol
« Reply #2 on: 2017 November 04 13:21:20 »
Thanks Mike, presumably that means that you might have to have a fair number of them if you want to divide projects up into subcategories?
« Reply #3 on: 2017 November 04 15:53:37 »
I was working on a project where I had 9 workspaces defined. I was glad when that was over and I could get rid of the extra workspaces.
Offline alcol
« Reply #4 on: 2017 November 05 08:15:51 »
Thanks for your input Mike, most helpful.
