Hello.
I'm building a darks library for my ASI1600MM-C and when doing the ImageIntegration, I see this error in the console window. It seems not critical as the integration seems to continue correctly but I don't know if it affects the final result if the sensor temperature readings are used in the calculations.
The fits have been captured with the latest SharpCap 3.0.4008 but I've seen the very same error in fits captured using a previous sharpcap versions.
Best regards
