Author Topic: StarRegistration not working on dithered subs?  (Read 2614 times)
Offline jamesRC
« on: 2017 October 16 20:54:52 »
I have a set of 21 subs all taken using dithering. When I try to register these images using StarRegister, it doesn't seem to have any effect. When I go through the "_r" registered images with Blink, the stars still jump about in a dithering pattern.
What might I be overlooking or missing, please?
Thanks!
James
Offline jamesRC
Re: StarRegistration not working on dithered subs?
« Reply #1 on: 2017 October 17 04:30:10 »
Oops I meant StarAlignment of course.  :-[
A second run of my set of 21 dithered subs through StarAlignment, gives me a set with the suffix "_r_r" and these are correctly star aligned. Why twice, though?
Thank you,
James
Offline drmikevt
« Reply #2 on: 2017 October 17 05:10:13 »
You must have forgotten to set a reference for the first run.  Try it again on a non-registered set of subs.  Make sure to set a reference frame.  If it works, then that is what happened.
Offline jamesRC
« Reply #3 on: 2017 October 17 07:35:59 »
Hi drmikevt,
The process won't even run without a reference so that wasn't it. After some more misadventures, I found my "set" of subs was actually two different groups together, and there was considerable difference in star locations between the two groups. Oops. For now, I'm assuming that was the problem.
Thanks anyway, man :-)
James
Offline jamesRC
« Reply #4 on: 2017 October 17 08:21:06 »
-continued-
That above wasn't  the problem, either. I still have to run StarAlignment twice and sometimes even that doesn't work. The subs are RGB by the way, does that have an effect? I need StarAlignment!  :yell: :blank:
James
Offline RickS
« Reply #5 on: 2017 October 17 18:06:37 »
I can't think of any obvious reason why this should happen.  If StarAlignment is encountering errors then I wouldn't expect it to be producing output files.  Have you checked the process console log to see if there are any hints in there?  StarAlignment displays a lot of information on what it is doing.
Offline jamesRC
« Reply #6 on: 2017 October 18 12:07:19 »
Hello RickS
Where is the Process Control log, please?
James
Offline jamesRC
« Reply #7 on: 2017 October 18 12:38:30 »
Aha.
My bad.
I copied and pasted from the process console to study the log.
From this log, I could see that StarAlignment is working just fine. All the images are registered very well and then put in a directory where I did not expect them to go. My error on the default/output directory option.
So cancel this question, all is solved. Thank you very much for responding, people, especially RickS!  8)
James
Offline RickS
« Reply #8 on: 2017 October 22 03:38:46 »
Glad you got the problem resolved, James.
