Author Topic: Light Calibration  (Read 2167 times)
Offline Farzad_k
Light Calibration
« on: 2017 October 09 13:05:28 »
I just want to be sure if I am using the right process.
I figure there are six steps in pre-processing:
[1] integrate biases, integrate darks
[2] calibrate flats - remove bias and dark out of the flats
[3] integrate flats
[4] calibrate lights, get dark, bias and flat out of them
[5] align lights
[6] integrate lights
Since in step 2 when flats cleaned of biases and darks, then in step 4 when lights are calibrated against biases and darks, the calibration of flats should be kept unchecked. Is this correct?
Re: Light Calibration
« Reply #1 on: 2017 October 09 15:55:21 »
that is correct. if the master flat is precalibrated, then the master flat should not be calibrated at the time ImageCalibration is run on the light frames.
Offline chris.bailey
« Reply #2 on: 2017 October 10 00:15:30 »
You might want to consider a step 4a Cosmetic Correction, especially if you are scaling darks and/or don't have well dithered light frames.
Chris
Offline bulrichl
« Reply #3 on: 2017 October 10 02:14:35 »
and if you are imaging with a digital single lens reflex (DSLR) or a one-shot color (OSC) camera, you have to debayer just before aligning the images.
Bernd
