Author Topic: Reference Light for StarAlign: Calibrated or Uncalibrated  (Read 2501 times)
Offline Farzad_k
Hello,
I am still learning the steps required for pre-processing and have a couple questions.
I believe alignment is a step after calibration. I am not sure why an uncalibrated Light should be used for star alignment when the calibrated ones are more cleaner.
Farzad
« Last Edit: 2017 October 09 10:17:14 by Farzad_k »
Offline RickS
Re: Reference Light for StarAlign: Calibrated or Uncalibrated
« Reply #1 on: 2017 October 09 17:12:32 »
I don't know of any reason why you shouldn't use a calibrated light as the registration reference.  I do it all the time...
Offline Farzad_k
« Reply #2 on: 2017 October 09 17:54:28 »
I don't see any reason either, which is why I asked. I have seen on some online videos they describe it that way.
In LRGB process, if calibration of the L and R, for example, are different for some reason, then the calibrated L frame that I am using as a reference may not necessarily work for alignment of the R images.
So you are doing it all the time and it works. Great, thanks.
Offline Geoff
« Reply #3 on: 2017 October 09 21:45:04 »
One reason for using an uncalibrated light frame is that it makes it convenient in the BatchPreprocessing script, where you have to specify the reference frame before you begin if you intend to use the script for both calibration and registration.
BTW, whether you use an uncalibrated or calibrated reference frame you should use the same one for all filters.
Don't panic! (Douglas Adams)
Offline RickS
« Reply #4 on: 2017 October 09 23:56:18 »
And choose it carefully, picking a reference with good (low) FWHM and Eccentricity.
Offline Farzad_k
« Reply #5 on: 2017 October 10 17:34:57 »
Roger that one. Thanks.
