Igor
Obviously, you can not do what you are doing. Do this instead:
- Choose a reference image and run Image Integration on your images using Linear fit rejection
- Use the resulting slope, dark and light rejection maps to create your crop. I start with the slope - apply Dynamic crop to it, adjust the sides and then save an instance to the work area (drag the triangle to a blank space on the work area). Apply that new instance to each reference frame and make sure the bad areas are cropped. Apply it to the integration frame and make sure it looks like you want, including rotation.
- When it is how you want, apply your crop - your image should be in it's final configuration - and rename that image 'registration_ref' or something.
- Use that image to register all your images, including the ones you used to make the image. This will crop, rotate and register your images all in one step.
- Now, you can integrate and drizzle as you like.
Good luck!
