Author Topic: Red Continuum Filter, star mask, eccentricity fix  (Read 2439 times)
Offline wolfman_4_ever
« on: 2017 October 07 17:13:44 »
I've read where others have used star masks to fix eccentricity issues with images.  Could I use a stacked and calibrated image of a Red Continuum filter to fix eccentricity issues?
Let's say I have some exposures from different narrowband filters.  Some aspects are great (under 5) while a few can be over 10.  Could I use the RC stack that has an eccentricity 3 to fix the rest of the other narrowband exposures?
Thoughts?  Or would I be better off trashing those bad subs?
A Red Continnum filter removes all the nebula, etc leaving only the stars.. aka a "real time" star mask.
Dave
« Last Edit: 2017 October 08 00:46:58 by wolfman_4_ever »
Re: Red Continuum Filter, star mask, eccentricity fix
« Reply #1 on: 2017 October 09 14:34:33 »
Anyone?  I did not think this would be a hard question to answer...
Dave
Offline drmikevt
« Reply #2 on: 2017 October 09 21:23:01 »
I'll take a stab and post some thoughts - take with a grain of salt...
First of all, you have to realize that a really bad eccentricity (or even a kind of bad one) will have effects across the entire image, not just the stars.  So, whatever you are imaging will also be fuzzier and this will affect the final image.  In general, it is best to discard bad FWHM and Eccentricity frames - you can't really correct for those image capture errors.  How bad?  That is up to you and how much of your data you can trash.
If you are going to improve things, it would be with the Deconvolution tool, but you need some really good SNR for it to work well and not make things worse.  There are a few good tutorials on youtube.  It can only do so much, though.
If all you want is better stars then you can also try replacing the stars in the image with the ones from the RC filter through a very good star mask using Pixelmath.  Make sure the backgrounds are very, very close. But, this does not solve the issue of the effect of bad frames on your target.
My advice would be to trash the bad frames - this will solve many issues before they occur, but at the expense of SNR.  As you move forward, you will 1) learn how to capture more consistent frames and 2) build the overhead into your workflow, knowing you need to capture 8 hrs to get 5 good hours (or whatever).
My .02
« Reply #3 on: 2017 October 09 22:20:43 »
Yup, that's a good point.. did not think about the actual subject/target.
Thanks.
Dave
