Moderator: please move to Bug Reports, should have posted there, sorry! --R
I'm running PixInsight verson 01.08.05.1353 Ripley (x64).
I used BPP to generate calibrated, cosmetic corrected, and registered monochrome frames with Generate Drizzle Data checked (L, R, G, B).
I used LocalNormalization on the registered frames from BPP.
I then attempted to run ImageIntegration with both L.Norm and Drizzle files added. They were added successfully (all images had <n> <d> prefixes in the Input Images window).
I clicked Apply Global in II and the Process Console showed the .xisf, .xnml and .xdrz files all being opened, but then I got a PCL Win32 System Exception. See the attached image for the hex code (read from address zero).
I removed the Drizzle files and reran the ImageIntegration process with no errors.
Let me know if I can provide any other data to help.
Rowland
