Author Topic: PI writing error on exit  (Read 1390 times)
Offline JFKoenig
« on: 2017 September 11 23:20:47 »
Hello
after updating PI to PI 01.08.05.1352 Riple(x64) on a ubuntu 16.04 machine
if I launch PI  with its icon
or by /usr/share/application/PixInsight
I got writing error when I close PI
error writing setting data (int) or error writing setting data (string)
if I launch it under sudo nautilus  /usr/share/application/PixInsight it work normaly
I suppose it is an permissions problem by I dont know how to resolve it!
Offline JFKoenig
Re: PI writing error on exit
« Reply #1 on: 2017 September 14 06:23:22 »
I solved my problem by searching all the pixinsigth files and changing the owner ( to me) and given them all permission
« Reply #2 on: 2017 September 22 01:28:05 »
This is a very anomalous situation that never happens on Linux under normal installation and working conditions. The errors you are reporting:
denote that your current user does not have write permissions on the corresponding home directory, which is wrong.
Please note that the owner of *all* files in /opt/PixInsight should always be root, since /opt is a system directory reserved for installed applications. Changing ownership as you have described is dangerous.
