Author Topic: DBE with no background  (Read 3132 times)
Offline rdryfoos
« on: 2017 September 04 11:42:20 »
The attached image is a 6 hour of Ha.  There is no background in the image.  I was not able to use DBE since there is no background.  In this situation, how is one to use DBE?
Rodd
Re: DBE with no background
« Reply #1 on: 2017 September 04 11:47:45 »
just try putting a few sample points in the darkest places and see what you get.
Offline Geoff
« Reply #2 on: 2017 September 04 13:29:29 »
Sometimes ABE works in these cases. Try it and see if the background it generates looks sensible.
Don't panic! (Douglas Adams)
Offline bob_franke
    • Focal Pointe Observatory
« Reply #3 on: 2017 September 04 19:37:13 »
Hi Rodd,
This is one of those images were you are probably better off to just leave it alone. I messed with the attached image a bit and only got two background models that made sense. Unfortunately, they were essentially the opposite of each other. ABE completely failed in making a usable model.
Sometimes you just have to go with what you have.
Bob
http://bf-astro.com/
Offline rdryfoos
« Reply #4 on: 2017 September 04 22:56:25 »
  But the dark areas are not background.  Is it ok to put points there?
Rodd
Offline rdryfoos
« Reply #5 on: 2017 September 04 23:29:56 »
Hi Rodd,
Bob
  Yes but when I add the OIII and SII I am sure I ill need to use DBE.  For the Ha alone I can probably get away without using it--but not on the SHO image.
Rodd
Offline bob_franke
« Reply #6 on: 2017 September 05 02:01:45 »
Rodd
I really don't think you have a problem, unless you shot the OIII with a very bright moon.
I took a look at my data, and you are going to have the same problem with the SII and OIII images. The OIII will be dark in the lower left-hand corner with the rest of the image filled with nebula. The SII image will be dark at the top with small dark areas on the right and bottom. Your Ha image looks just like mine.
All three color channels will be problematic for creating a valid background model. With my image, I did not flatten any of the channels and everything came out fine.
This is color mapped narrowband imaging and no one will be able to say one way or the other that your image is not correct. :-)
–Bob
Offline rdryfoos
« Reply #7 on: 2017 September 06 13:42:57 »
Rodd
–Bob
  Well--that just begs the question of what to do under similar situations with RGB data.  I run into this problem for the same reason  there as well.
Rodd
« Reply #8 on: 2017 September 06 14:04:11 »
i think vicent once suggested, if you are really invested in this, to wait a month or two and then image the exact same part of the sky, (from an alt-az perspective), during the same moon age, so that you can build a background model of your light pollution for the original image. it's not perfect, and it is difficult, but it's the closest you might get...
