Author Topic: PCL Win32 System Exception  (Read 1682 times)
Offline timc770
« on: 2017 August 27 13:42:23 »
Hello,
I'm getting the following error when running the Star Alignment Process:
At address 00007FFCC0099E08 with exception code C0000005 :
Access violation: invalid memory read operation at address FFFFCCDA92215050
Per the other posts regarding this type of issue, I tried unchecking automated UI scaling in global preferences with no luck.  I also updated to the very latest version of PI (1.8.5) and still get the issue.  I have two different Dell laptops (different models) running Windows 10 and still have the same issue, so I'm stuck.  Does anyone have any suggestions for me to try?
p.s., I've processed quite a few pictures with PI in the past with the same laptop and OS and never had this issue.  It popped up last January out of the blue.  I walked away from it for quite a while but am now back at it hoping to finish processing my last effort (I don't image anymore but have this last one unfinished project lingering out there).
Tim
Re: PCL Win32 System Exception
« Reply #1 on: 2017 August 27 13:59:29 »
This cannot be reproduced on any platform with our data sets, neither with version 1.8.4 nor with 1.8.5. Can you upload a set of images where this problem can be reproduced?
Offline timc770
« Reply #2 on: 2017 August 27 18:01:56 »
Hi - I uploaded the five images that I'm trying to align with the Star Alignment process here.  Thanks for any help.
https://smile.amazon.com/clouddrive/share/3FnD3qfSJsHUXEZ65AVRgMZC3mZKk6wK8OmiMMN4qZ7
« Reply #3 on: 2017 August 28 05:01:00 »
Hi Tim,
Thank you so much for uploading the image. This bug is now fixed with an update I've just released for all platforms.
The problem was being caused by extremely low or insignificant pixel values in combination with very specific structural image properties. In the case of this image, there is a single pixel at coordinates X=6753 Y=4263 with a value around 10-10, which is obviously insignificant for a 32-bit floating point image. This single pixel was fooling our star detection routines in this particular image. As I've said, this problem is now completely fixed. Thank you, and sorry for the inconvenience.
Offline timc770
« Reply #4 on: 2017 August 28 05:32:53 »
Thanks Juan! I'll give it a try as soon as I get a chance.
« Reply #5 on: 2017 August 28 07:54:18 »
Juan,
You appear to have been sitting on this problem for about 11 hours - your response to bug-fixes needs to be a little less 'tardy' (even though you will no doubt claim to have been asleep some of that time).
Other software packages, would have taken 11 months to react, and would then have offered a solution by way of a chargeable upgrade - surely you could at least strive to reach their standard  ;)
Offline timc770
« Reply #6 on: 2017 August 28 16:06:57 »
Just confirming that the patch fixed my issue.  Thanks again for the super fast resolution!
« Reply #7 on: 2017 August 29 04:23:41 »
Hi Tim,
Glad to know it's working. Let us see your image when you finish processing these excellent data.
« Reply #8 on: 2017 August 29 04:25:41 »
Niall,
I keep trying! And they use FITS and all...  ;D
