Author Topic: Process Explorer question  (Read 2153 times)
Offline tloebl
« on: 2017 August 16 07:18:34 »
The new V1.8.5, Process explorer now opens recently used and most used icons by default. Is there a way for my favorites to open on top when PI opens  and Process Explorer is launched, the way it worked in 1.8.4? Did I miss a check box somewhere?
Tom
Re: Process Explorer question
« Reply #1 on: 2017 August 21 07:40:38 »
Hi Tom,
- Select EDIT > Global Preferences.
- On the Preferences window, select the Main Window / Startup section (it is the first one, hence selected by default).
- Uncheck the Expand recently... and Expand most... options.
- Check the Expand favorites... option.
- Click on Apply Global or press F6 to execute.
Let me know if this helps. However, if you give the new Process Explorer Recently Used and Most Used items a try, you may like them better than the classical Favorites list.
Offline tloebl
« Reply #2 on: 2017 August 21 10:16:21 »
Thanks Juan, I must be blind not seeing the option on the first choice of global preferences. Thanks for the info. I will try both ways to see over long term which works best for me.
Tom
