Author Topic: 1.8.5 missing L-button on toolbar  (Read 2715 times)
Offline TobiasLindemann
    • Trackingstation
« on: 2017 August 04 08:10:53 »
A minor bug, but I am missing the L-button (extract lightness) on the toolbar . Is this with indend?
Greetings
Tobias
Re: 1.8.5 missing L-button on toolbar
« Reply #1 on: 2017 August 06 14:37:21 »
Opps, I hadn't noticed it! There are two missing icons in that toolbar.
I don't know if Juan commented the reason in some previous post, but this is a very useful button, I will miss it if cannot be restored.
I am using Linux, what is your system Tobias?
Saludos, Alejandro.
« Reply #2 on: 2017 August 06 15:56:16 »
Alejandro
I think it's a high dpi issue. If I lower the resolution for my monitor or play with the scaling factors in the global preferences you can make it come and go away. My guess it's a QT issue.
« Reply #3 on: 2017 August 06 17:40:41 »
Thanks Mike! I went from 70 to 120 dpi without luck. Not critical but would be a pity not having it.
Saludos, Alejandro.
    • Trackingstation
« Reply #4 on: 2017 August 07 01:31:19 »
I have Windows, on Mac OS it is obviously the same problem.
Offline chris.bailey
« Reply #5 on: 2017 August 07 02:04:34 »
Strange, it is there on my Mac install.
Chris
« Reply #6 on: 2017 August 07 02:58:57 »
This is not a bug, it is intentional. When the application is executed on small monitors with horizontal resolutions under 1920 logical pixels, this icon is not shown. This is to favor inclusion of more important (IMO) icons, such as AutoStretch icons, in the default toolbar configuration.
If there is major consensus in that this toolbar button is so important, I can rebuild the ColorSpaces module to bring it back at all resolutions. Anyway, you can always extract lightness with IMAGE > Extract > Lightness (CIE L*), or directly with the ChannelExtraction tool.
    • Trackingstation
« Reply #7 on: 2017 August 07 03:09:52 »
Hi Juan,
thank you for your answer. My resolution is 1920x1080 and the icon is not shown, although there were more then enough space for it. I am pretty sure in the previous version it was shown on the same resolution. I use it very often for building masks, so i would be very lucky if I could use it the easy way through the toolbar.
Tobias
« Reply #8 on: 2017 August 07 03:54:39 »
Hi Tobias,
Unfortunately, the icon is hidden for resolutions <= 1920. Don't worry, the icon will be shown again at all resolutions. I'll release an update to the ColorSpaces module as soon as possible. Now I see that my decision was wrong; thank you for pointing this out.
    • Trackingstation
« Reply #9 on: 2017 August 07 13:38:31 »
Thank you very much Juan :-)
Offline agavephoto
    • DrewMedlin.com
« Reply #10 on: 2017 August 08 07:47:46 »
Thanks for bringing this back! I use this button almost every time I process.
« Reply #11 on: 2017 August 09 03:19:59 »
I have just released an update to the ColorSpaces module for all platforms. The Extract CIE L* component toolbar button is now shown at all screen resolutions.
    • Trackingstation
« Reply #12 on: 2017 August 09 13:05:16 »
Thanks Juan :)
