Hi, and welcome to PixInsight.
Given that your license allows you to install on multiple machines (for personal, non-commercial use) then, if you haven't done so already, I would delete the install that you have on your laptop (which may not be the 'commercial' version, and then download and install the full commercial version in its place.
Remember to keep a copy of your PixInsight license file somewhere safe - so that you can copy it back into each and every machine that you might be using PixInsight on. (If you go to the PixInsight Home page, and then navigate into the Resources section and then down to the FAQ section, you should find links to information about PI licensing queries).
Hope this helps.
