Author Topic: Star Alignment - can't add files  (Read 2050 times)
Offline jcinpv
« on: 2017 May 06 00:12:22 »
I tried to use SAM on a set of preprocessed images after the integration failed (only two images accepted out of 10 collected). After selecting the reference file, none of the other buttons were active. I couldn't add files or anything else. So I went to another image set that worked before and again I could not add files. Nothing I do will make the other buttons active.
John C.
Paulden, AZ
Offline TobiasLindemann
    • Trackingstation
Re: Star Alignment - can't add files
« Reply #1 on: 2017 May 06 04:26:34 »
Is your working mode "RegisterMatchImages"?
Offline jcinpv
« Reply #2 on: 2017 May 07 22:37:33 »
I have accidentally discovered the reason for this problem. When I start PI by loading Warren's PI Icons or even load those icons after starting, the problem appears. If I don't load Warren's PI Icons, then the problem is not there.
I deleted Warren's icons and recreated them from scratch and the problem is gone.
John C.
Paulden, AZ
