Author Topic: First Time User Troubles, STF, Zoom Shortcut, Preview  (Read 2548 times)
Offline msadler13
The main issue I have is with the STF. I was doing a DBE process and wanted to use the STF. I tried the auto stf and I got a way too bright result with no way to adjust it. When I brought up the STF in the process explorer nothing I did made any affect. I could do a reset but nothing else. If I used the curves transformation I was able to change the image. I guess I don't understand the whole stf function.
The other issues are not as big of an issue. One is that the Cnt ++ shortcut does not zoom in, but the zoom out shortcut works.
The other issue is that there does not seem to be a way to draw a preview window. When I go the preview window and enter a new preview it gives a dialog window that asks for the coordinates of the preview window.
Mike Adler
Offline Duncan
Re: First Time User Troubles, STF, Zoom Shortcut, Preview
« Reply #1 on: 2017 March 11 00:23:18 »
Starting with the first thing:
What are you trying to adjust that doesn't work? You should be able to move the sliders in STF to reduce the displayed brightness.
Offline bulrichl
« Reply #2 on: 2017 March 11 06:33:45 »
Zoom in:  Control key + 'plus'
Zoom out: Control key + 'minus'
If you have a mouse with a scroll wheel, it is most convenient to use that.
Verify that 'Show Previews' is selected in the PREVIEW menu. Then press Alt + N for creating a New Preview which is done with the mouse. If you want to correct the coordinates you can do so immediately with the mouse (press the left mouse button inside the green rectangle and shift to shift the whole preview, press the left mouse button on a margin or a corner and shift to enlarge/reduce the size of the preview). Alternatively you can select 'Modify Preview' and alter the numbers.
I find it most convenient to have the Preview Tool Bar active, so you directly see the symbol for e. g. Show Previews without having to go to the menu. Some more very helpful Tool Bars are:
Image, Display, Mode, Zoom, Preview, Mask, Screen Transfer, View Selector, Workspace Selector, Position, Readout and Information. The active Tool Bars are set in the VIEW/Tool Bars menu. I recommend to select these.
Bernd
