Author Topic: Star size Issue in HA versus OIII  (Read 3267 times)
Offline jerryyyyy
    • Astrobin Images
« on: 2017 March 05 07:59:02 »
I have been processing my data on Thor’s Helmet (30h) and the $%$!! stars in HA are bigger than those in O-III I have tried deconvoluting the HA and not the O-III and various star shrinking tricks.  This is very tricky since there is not a huge difference between the two images.  When you subtract them in PI you will see both the rings generated around stars for having too big HA, but also what I have will become the red edge around the Helmet where there is a bigger HA signal than O-III.
Maybe this is less of a problem with Astrodon filters than Baaders… $$ upgrade for me.
Insights appreciated.
Takahashi 180ED
Astrophysics Mach1
SBIG STT-8300M and Nikon D800
Offline aworonow
    • Faint Light Photography
Re: Star size Issue in HA versus OIII
« Reply #1 on: 2017 March 05 12:33:55 »
You could try making a star mask in Ha, inverting it, and using the morphological transformation=erosion to shrink the stars.
Alex
« Reply #2 on: 2017 March 05 14:06:51 »
Hi jerryyyyy
Could you upload to dropbox or some other site a linear cropped section of the Ha and O-III images with an offending star?
Offline jerryyyyy
    • Astrobin Images
« Reply #3 on: 2017 March 05 18:29:43 »
Hi jerryyyyy
Thanks, will send a OneDrive link to you in a PM.  I think you'll see the problem.  These files were drizzled and cropped because of some problems with the horizon.  I'll put the original smaller images in too.
Takahashi 180ED
Astrophysics Mach1
Offline jerryyyyy
    • Astrobin Images
« Reply #4 on: 2017 March 05 18:33:02 »
Alex
Thanks, I tried this but perhaps my settings were not perfect.  I sent you a link to the files if you want to take a shot....
Takahashi 180ED
Astrophysics Mach1
« Reply #5 on: 2017 March 05 18:40:42 »
jerryyyyy
Thanks. I'll see what I can do.
« Reply #6 on: 2017 March 05 19:51:17 »
jerryyyyy
I did a quick look at a crop of your image. This is real basic stuff. Linear fit the images. Make a star mask from the linear Ha image and reduce the levels of the Ha stars using PixelMath by  a very small amount. Of course whatever amount is really needed can be used but all done to the linear image Ha. This is how I would attach this as I think it would have the least impact or artifacts on the image.
Here is a link to a video showing what I did. There is no audio but I think you can follow along. By the way if the video is fuzzy just pause it and restart.
https://drive.google.com/file/d/0B13r3kYqTf8NRzItODJaNDdzQkE/view?usp=sharing
This is going to be a very nice image when your done!
« Reply #7 on: 2017 March 05 20:30:22 »
i feel like part of the problem is that the images are slightly out of focus... this may have exacerbated the star sizes.
